weld or summit stars
Old 06-01-2008, 08:13 PM
camaro468's Avatar
Default weld or summit stars
i am thinking about getting summit stars becouse of the price and was wondering what yall think and what back space and i will have to grind right any input would be great
Old 06-01-2008, 10:22 PM
CNTLSE 1's Avatar
Kinda the same question but open to wheel choices and I want to avoid grinding. Sorry to hijack
Old 06-01-2008, 10:52 PM
SIC LSX's Avatar
If you want 15x8'a rears jegs or summit stars. If you want 15x10 welds
Old 06-01-2008, 10:54 PM
98trans-am's Avatar
I just ordered the summit stars like 30 mins. ago. theyre 15x8 -5x4.75 and 5.5 bs. from what ive read in older threads they will require some grinding in the back but very minimal, unless you have lt1 brakes then theyll clear no prob. someone correct me if im wrong but thats what ive been reading thus far. also read you can use youre stock lugnuts and wheel studs. i paid 251.00 total so the price is not bad at all, but i only ordered two for the rear.
Old 06-01-2008, 11:08 PM
THE_OTHER_GM_BIRD's Avatar
so 15x10 welds with 7.5 bs will clear LT1 rear brakes without grinding??? If thats true then YESSsS! haha does anyone know for sure?
Old 06-01-2008, 11:39 PM
SIC LSX's Avatar
i just helped put some 15x10 7.5 on lt1 car with no spacer and had very little grinding not bad at all, Just took off those little groves that stick out took just a few mins it made the caliper look alot better too. A spacer might help but no spacer you will need to grind on lt1 cars too
Old 06-01-2008, 11:45 PM
ok thanks
Old 06-01-2008, 11:53 PM
SYon22s's Avatar
summit stars...15x4 fronts, 15x8 rears 5.5BS
Old 06-13-2008, 09:03 PM
camaro468's Avatar
ya thats what i am talking about looks great i want hood like that too
Old 06-13-2008, 09:22 PM
Camaro396's Avatar
Welds look way better imo.
Old 06-14-2008, 03:35 PM
camaro468's Avatar
yea but i heard you have to grind the hell out of the capilers to get them to fit and they are twice the amount of summit stars
Old 06-14-2008, 04:55 PM
sixvi6-camaro's Avatar
I wasn't liking mine until I left the center caps off. imo.. they look 10x better with no center cap and the hub panted black. Mine are 15x4 fronts with a 1/4" spacer. rear is 15x8 5.5 BS with a Hoosier 275/50 DR.
No they don't stick out either... for whatever reason in the pic it looks like they stick out but they don't. Probably due to the stock springs I'm still running and the fact I took a lot of weight out of the car.. the car sits higher than stock now.
Quick Reply: weld or summit stars
