Will these wheels fit OK??
Old 06-13-2008, 05:28 PM
my01ws6's Avatar
Default Will these wheels fit OK??
This will be on my 01 WS6
Front 17 x 9.5"- 56mm
Rear 18 x 10.5"- 56mm
I will be running 275/40/17 tires for the fronts and 295-305/35/18 for the rear.
Old 06-13-2008, 07:13 PM
98MNBZ28's Avatar
the front ok,but the rear BFH @ the minimum
Old 06-13-2008, 07:26 PM
my01ws6's Avatar
I will have to bang the rear fenders for a fact?
Old 06-13-2008, 07:37 PM
TomZwheels's Avatar
You will be able to run some 295's without mods. Some 295's are not as wide as others.
Old 06-13-2008, 08:25 PM
my01ws6's Avatar
So I can run 295s with using a BFH on the inner fenders?
Old 06-13-2008, 08:29 PM
doomsdaymachine's Avatar
i had the z06 on my t.a uknow the regular 17 n 18 inch...
n i had to use spacers, in maros is diferent...
just make sure it does fit good before buying.
Old 06-14-2008, 09:31 AM
my01ws6's Avatar
yeah I want to make sure 100% that they will fit with no modification.
Old 06-14-2008, 03:39 PM
01SuperSport's Avatar
I fit a 305 35 18 nitto drag radial on a 18x10.5 58mm offset rim on my camaro. It rubs very very rarely.
