17x11 question
17x11 question
I plan to drop my z28 1" and put TT2's 17x9.5 front & 17x11 rear w/315/35/17's in the rear. Will they rub the fender or inside of the wheel well? Do I need spacers?
My car is lowered on Eibach Sportlines... I run BFG 315 drag radials... one day I was pulling into a driveway and the car twisted a little bit and hit the tire and cut it a little bit...
Just to be safe, roll the fenders...check with your local speed shops, usually they have a roller you can rent and do it yourself or pay them..or maybe a fancy tire shop that sells the big bling bling wheels.
Also...ADJUSTABLE PANHARD BAR! Get the on-car double adjustable one...just a little bit more..but makes adjusting so easy. And whenever I get my car up on a lift...or jacked up high enough..the wheels get caught on the bumpstops..so you might want to pound on them a little bit.
Drive your car for a couple days, then take the wheels off and see if they have been rubbing on the inner wheel wells any..hit those spots with a hammer.
thats another thing the adj. panhard. do u need it ASAP when u do 315? cuz ill be doing my suspension work later on after rims/tires and such.
Location: Your girl's back door giving her the long stroke while you're at work
My LT1 is lowered almost two inches with a Pro Kit. They only thing I did was clearance the inner fender on both sides and roll the lips on the quarters. My Sumitomos don't rub anywhere now
