2002 Camaro Z28 Packs 427 Cubic Inches of LS Power
Camaro Z28 isn’t pretty right now, but it has all of the parts to be an awesome street and strip car.
It can be argued that if you want to go very fast at the drag strip, a fourth generation Chevrolet Camaro is one of the best cars on which to base your build. The standard LS1 engine can be modified to make monster power and if the builder wants to start with more power, any of the other LS engines will slide right into the Camaro engine bay with a little massaging. As a result, it is not uncommon to see this era of the Chevy muscle car dominating multiple classes at your local drag strip, but like any vehicle, building a 4g Camaro to run in the 9s takes some knowledge that not everyone possesses.
Fortunately, while flipping through the LS1Tech Marketplace, we came across this 2002 Chevrolet Camaro Z28 that has been built to rule the quarter mile, but it needs some help in achieving its full potential.
Camaro Z28 Introduction
When “marksboy7” posted this 2002 Camaro Z28 for sale in the marketplace, he began with a quick rundown on why he is selling, what the car needs and what he plans to get to replace the primered Chevy.
“I really don’t want to but I’ve decided to sell my toy. Even though I’ve never had it to the track or drive it much like I had planned since I don’t have current tags or insurance on it I still love to go out and crank it just to listen to it run. It took me a couple years to get where I’m at with it and I’ve just kinda lost interest. I fish or tractor pull most weekends so my loss can be your gain. I have around 33k in it. Get a good tune in it and some shiny new paint and you’ll practically have a brand new racecar. I’d like to put the money from this into a new duramax. Pretty much everything but the accessory drive and brakes are new. It only has 201 miles on it since I built it. Those are just cruising miles where I would take it out for a drive. Only problem I guess you could say it has is it must have a faulty ignition because sometimes it will crank on the first try and sometimes I have to let it sit a few mins to get it to start. It did this before I built it as well. I’ll try to list what all I have in it.”
He also included a handful of pictures, showing the car from multiple angles including the interior and under the hood, along with a shot of the engine on a stand prior to being installed.
The Mod List
Next, the OP provided a detailed modification list that touched on each key area of the Camaro, starting with the engine, then moving onto the transmission, the rear differential, the suspension, the interior and the wheels and tires.
“Engine:
Texas Speed & Performance LS3 427 shortblock
Callies Compstar crank
235cc Trickflowheads from TEA
Harland Sharp rockers
Comp cam spec’d by Pat G
Manton pushrods
Morel link bar lifters
Fast 102 LSXR intake ported by Mamo
Fast 102 Billet TB
60lb injectors and rails from Nasty Nate
ATI Super Damper Balancer
Meziere electric water pump
2 x 3.5 ARH headers ceramic coatedTrans:
PerformabuiltLVL 2 4L60e
Yank PT4000 converterRearend:
Midwest Chassis Fab 9 w/3.50 gear
Backbraced
Fill Cap
Tow Loops
Watts Link
Transverse shock mounts
Drag bar
35 spline Strange axles
1/2″ studsSuspension:
Front – UMI upper and lower control arms, k-member, all chromoly, Strano hollow swaybar
Rear – Midwest Chassis, lca’s, torque arm
Strange coilover shocks front and rear
Midwest Chassis weld on subframe connectors
It’s not suspension but also have Midwest Chassis front and rear light weight bumper supportsInterior:
Midwest Chassis 6pt rollbar – chromoly
Corbeau A4 racing seats – black leather
Rear seats have been deleted along with all brackets
Triple A-pillar gauge pod with AFR, Fuel pressure, and Aeroforce scan gaugeWheels/Tires:
Deep dish replica C5 wheels 18×10.5
BFGoodrich KDW2 tires 295/35/18 – I would say with less than 3000 miles on them”
Based on this mod list, this 2002 Camaro Z28 has all of the parts to be a great street and strip car. The note about tuning leads us to believe that this Chevy isn’t running properly right now, which might be one of the reasons why the OP is looking to get rid of it, but the car comes with a long list of quality components that can lead to a very fast street car.
Of course, if you are going to drive it on the street, or even if you are buying it for a race-only car, we would hope that you would at least hit Maaco for a quick coat of paint, as it is pretty ugly as it sits. However, ugly doesn’t impact elapsed times, so if you are looking for a solid 4g Camaro race car, this one is only $24,500 away from being in your garage.
