‘LS1Tech’ Member’s LS-swapped Fox Body Cobra Clone Slays
Fox Body Mustang looks like a 1993 Cobra, but it is actually a 1990 GT Fastback with LS power.
Some people will tell you that the best way to build a fast Fox Body Mustang it to replace the Ford engine with a GM LS V8. This has become a popular swap with loads of support, but not everyone has the mechanical know-how to change engines. Fortunately, Hilrod posted a 1993 Ford Mustang Cobra clone in the LS1Tech Marketplace that has already undergone the LS swap.
Best of all, this 1990-turned-1993 Mustang Cobra has a clean interior and exterior, so in addition to being quicker, it looks good enough to proudly displayed at your local Cars and Coffee.
1993 Cobra Clone with LS Power
When the OP first posted his 1990 Ford Mustang to the forum, he provided a ton of information in a relatively unique order. In most cases, someone selling a car with an LS swap on an LS-based website will start by talking about the engine swap. Instead, the OP here saved the best for last, talking about every other aspect of the car before getting to the engine details.
This is a 1990 Mustang, it looks like a 1993 Cobra. It was built a black on black GT I believe. I bought it as a gutted painted shell. The body had the doors fenders and hatch all replaced before paint. The body isn’t perfect, but super nice. 15 year old paint so a few small nicks but overall very good job done. Carbon fiber cowl hood. All weatherstrip new. Factory sunroof.
I’ve spent over a year putting it back together. The interior is very nice and is now black cloth. Seats are power,(driver) with power lumbar. New carpet front and rear, new door panels, headliner and way too much more to list.
All new suspension. Bushings, ball joints, struts, shocks, springs, and most bolts. The exhaust is new, 3 in to 2 1/2 with xpipe. It had super turbo mufflers but was too quiet and has Jegs 2 chamber flows now. It sounds like every other fox now. Exactly like a normal fox. The driveshaft is new, the clutch is new, as is the scattershield. New clutch and brake pedals, with hydroboost and all wheel later Cobra 5 lug brakes. All new brake and fuel lines, and fuel tank with mostly stainless and or braided teflon lines. Hydraulic clutch slave and master setup, New TKO600 modded to shift right or at high RPM. LS1 Camaro radiator and fans. Smoothed engine bay and fully painted underside. 95 8.8 factory limited slip with new bearings and seals and axles, 3.27(I think or 3.31) gears , and adjustable upper control arms.
Last a 130,000 mile aluminum 5.3 with gen 4 rods and pistons, sloppy stage 2 cam, with springs and retainers. New pushrods, all gaskets and seals, ARP headbolts, double roller timing chain and new oil pump. Holley oil pan. Gm carbed intake with a new 670 carb with choke. The car has a 160 speedo and reads 16 miles as I didn’t have/know what it really has. New 93 Cobra R replica wheels, 17×9 and 17×8. New 16 mile front nitto tires rear slightly used nitto drags. I’m tired of typing so if I didn’t say it’s new. I would love to trade plus cash for another project. Fairmonts, Gbody Malibus, or most anything. Weirder the better. If the ad is up it’s for sale. I don’t have time to answer over and over if it’s still for sale. There is a build thread here on Tech in the swap section. Price is FIRM.Thanks for looking.
There is a new stereo with all new speakers(except tweeters), with aux port and usb. Aftermarket gauges in the lower dash, along with all stock gauges working. Everything works as stock but better except AC. Dash unit and controls are there but nothing forward of firewall. Heater(new core) works as it should.
The OP also included an array of pictures, although he didn’t include any good shots of the engine. He did, however, share enough pictures to clearly show the quality of this 1993 Cobra clone.
Drive It or Build It
This 1990 Ford Mustang-turned-1993 Cobra sounds like it is a great turnkey driver, with all of the work of an LS swap already handled. The carbureted induction setup isn’t ideal for making big power, but that could be addressed easily enough. A few tweaks under the hood could turn this 1993 Cobra into a wicked street machine, but if you just want a fun-to-drive Fox Body with LS power, this could be your ideal cruiser.
Click here for a closer look at this Ford Mustang Cobra clone in the LS1Tech Marketplace.
