Pennzoil Presents Dyno Wednesday: SAM Racing’s LSX Makes 1064 Naturally Aspriated Horsepower
![DynoWednesdayPennzoil-070313](https://ls1tech.com/wp-content/uploads/2013/06/DynoWednesdayPennzoil-070313.jpg)
As if a HOSS 4th Gen. Camaro isn’t special enough, SAM has to go and throw an all-motor bullet like this under the hood and shatter every applicable record in the book, like the Fastest All Motor LS Camaro with stock suspension. Motivation comes from the aforementioned 438 that uses an LSX block, C5R heads and two Holley Throttle Bodies feeding a Beck Sheet Metal intake manifold.
Seriously, crank your speakers and listen to this beast spin to 9000 RPM. This is what nearly 1100 naturally aspirated horses sounds like! Come get some!
About Pennzoil®
At Pennzoil®, we know it doesn’t matter what you do in your car, it only matters what you put in it. That’s why our synthetics have been the driving force behind clean engine technology and unsurpassed engine protection.* We formulate our state-of-the-art motor oils to keep engines running stronger and longer so you can protect your car and the memories made in it.
Pennzoil® is the most trusted motor oil brand in America.** Each Pennzoil motor oil is formulated with special Active Cleansing Agents™ that not only help prevent sludge, but also clean out existing sludge. The full line of Pennzoil quality products includes Pennzoil Ultra™ motor oil with Hyper Cleansing Technology™, Pennzoil Platinum® Full Synthetic motor oil, Pennzoil® motor oil, Pennzoil Gold™ motor oil, Pennzoil® High Mileage Vehicle® motor oil, and Pennzoil Marine® engine oil. For more information about Pennzoil products, please visit www.pennzoil.com. *
* Based on Sequence IVA wear and VG sludge tests sing SAE 5W-30.
** Based on a survey of licensed drivers conducted by a leading research firm January 2005 – December 2011.
