Seven Cool Holley Holiday Gifts
Holley Performance gifts us nice discounts on a slew of cool parts and other fun stuff through the end of December.
The holidays are right around the corner, which means a lot of things. Firstly, it means spending time with your family and loved ones. Which may or may not be a bad thing, depending on how you look at it. But the holidays are also a time to give and receive gifts, which is definitely a good thing. And while you’ve likely already got a long list ready for Santa, Holley Performance is more than willing to give you some more solid ideas for your build.
Right now, the legendary maker and seller of performance parts is also offering a nice (up to) 20% discount on a curated list of goodies, too. They’re calling this sale Happy Holleydays, which is both clever and humorous. The event runs now through December 31, so you’ve got plenty of time to take advantage. And in case you don’t have time to sift through the many items Holley is offering up at a discount, we went through the entire list and picked out seven of our favorites, which we’ve assembled here for your viewing pleasure.
Hurst Universal Roll/Control, Line/Loc Kit
Those that love to hit the track (read:you) also appreciate the benefits of a hard launch. And it’s hard to beat the benefits a line loc kit can provide. Hurst’s Roll Control kit will help you shave precious tenths off your 60-foot times on the cheap. It’s universal, and adaptable to most hydraulic brake systems. And according to Hurst, the kit provides a super-quick 1/100,000 of a second release time. It’s also built solidly, as vibration tests have seen up to 30 G’s applied without mechanical failure. Not too shabby for a hair over a hundred bucks.
MSD Chevy Small Block Hall-Effect Crank Trigger Kit
If you’re running a small block Chevy and you’re looking for the most effective and accurate way to trigger your electronic fuel-injection, MSD has a nice solution. This new crank trigger kit comes equipped with a Hall-Effect sensor, which helps improve accuracy. It’s easy to install, and uses tough aluminum construction on the trigger wheel to prevent timing malfunctions, too.
Holley EFI 6.86″ Pro Digital Dash
One of our personal favorite mods is Holley’s Pro Digital Dash, which is thankfully included in the Holleydays sale. Unlike factory or analog gauges, it’s extremely precise and responsive, perfect for high horsepower applications. It’s also fully customizable, with a high resolution screen that’s visible even in the worst conditions. If you’re running a Dominator, HP, Terminator X, or Sniper EFI setup, this dash is plug and play. And thanks to a host of input and outputs, it’s also easy to build upon in the future.
Holley Single Plane Split-Design Race Intake Manifold- GM LS3/L92-4150
If you’re running a Gen III or IV LS equipped with LS3/L92 cylinder heads, Holley’s new single plane split-design race intake manifold is a solid choice. The two-piece split feature used to be relegated to only super expensive intakes, but this one won’t break the bank. It’s designed to provide max performance all the way to 7,000 rpm, at roughly half the price of other split race intake manifolds.
Holley Small Block Chevy Mid-Mount Complete Accessory System
Unlike most accessory drives, Holley’s Mid-Mount system features a bracketless design. All of the accessories bolt directly to the water pump, which results in a cleaner installation. This minimizes the “ugly” stuff hanging off your small block Chevy, instead showing off the real prize – the engine itself. The Holley alternator included in the kit is equally innovative. It shares its design efficiencies with the C7 Corvette, which will undoubtedly help modernize your old school small block just a tad.
Holley In-Tank Retrofit Fuel Module 525 LPH Return Style
Most everybody is always looking for ways to feed their engine more fuel, which is why return-style systems have become so popular. And this particular Holley 525 LPH retrofit kit does just that, supplying enough gas to support up to 1,200 hp for fuel-injected engines, or 1,450 for carbs. Better yet, installing it requires nothing more than basic tools, with no welding or fabrication needed.
Holley Chevy Ramp Truck and Chevy Camaro 1:64 Diecast Model
Even if you’re not in the market for more parts, we couldn’t help but find ourselves enamored with this cool diecast model duo. Featuring a ’71 Camaro and a ’67 Chevy ramp truck to haul it to and from the track, these “toys” are more than cool enough to land a spot on our workbench.
These are just a small handful of the many cool things Holley Performance has on sale for Holleydays. So be sure and head over here to scope them all out. Even if you can’t convince someone else to buy them for you, there’s nothing wrong with a little self-gifting, now is there?
Photos: Holley Performance
