TopScan Bluetooth Device Makes Error Code Diagnostics a Cinch at Home (UPDATED)
By -
Transform your phone into a high tech scanning tool and (re)program basic functions with the wireless TopScan OBDII reader by Topdon.
A “Check Engine Light” (CEL) can invoke a lot of feelings in a car owner–fear, anxiety, uncertainty, annoyance, you name it. For those who have the aptitude and patience, hooking up your car to a highly-sophisticated (and usually expensive) diagnostic tool and researching error codes is a not a problem. Enthusiast or otherwise, not every car owner has access to these types of machines, nor the skill to fully use them.
With Topdon’s TopScan, you can now take control of your car’s health without schlepping over to the mechanic and paying annoying, sometimes absurd diagnostic fees. You can even program basic functions and reset parameters (like indexing windows, resetting oil life, etc.) with an incredibly-simple and interactive mobile app. Best of all, it has Bluetooth 5.0 connectivity, so TopScan can communicate with your vehicle from up to 33 feet (10 meters) away.
TopScan is a pocket-sized device that transforms your phone into a scan tool and is much more than your basic LCD-screen code reader. You get free lifetime access to all 10 modes of OBD2 port testing. Setup is dead simple–all you need to do is connect the device to your phone’s OBD2 port and launch the app.
Comprehensive Functionality
The device in excels at the fundamentals; it is capable of efficiently reading and clearing fault codes, offering support for over 60 vehicle makes, spanning American, Asian, and European vehicles.
From reading and clearing DTCs (Diagnostic Trouble Code) to accessing Live Data, I/M Readiness Monitor Status, and Freeze Frame Data, this tool has you covered. You can even perform O2 Sensor Testing, Onboard Monitor Testing, Evap Testing, Read VIN and utilize the DTC Look Up feature, which, quite frankly, save loads of time for the end-user by jumping straight to your phone’s browser for instant results.
Treasure Trove of Repair Knowledge
It’s not always obvious where to start when it comes to vehicle diagnosis, so TopScan’s comprehensive repair data library is a boon, particularly for beginners and DIYers looking to quickly familiarize themselves with vehicle data, save money and tackle minor vehicle problems on their own.
The repair information includes a DTC Repair Guide, Technical Service Bulletin (TSB), DLC Location, and Warning Light Library options. right on the home screen. Best of all, you’ll have all the guidance you need to resolve issues efficiently.
Bi-directional Control
This feature grants you access to vehicle-specific subsystems and components (i.e., fuel injectors, coolant pumps, windows, windshield wipers, etc.) that drive the actuators to perform specific functions. You can analyze and locate faulty parts with precision,
In this case, I discovered that my passenger door’s lock actuator had given up the ghost when I initially thought it was a bad BCM. Had I taken this to a dealer, I’d have probably shelled out a pretty penny for diagnostics, parts and labor for a 45-min direct-replacement job.
However, bear in mind that the Camaro’s BCM coding is GM proprietary. So while you may be able to control the ECM and TCM regarding idle learn, engine speed and throttle positioning, you will not be able to control the locks, windows, latches or anything else the BCM controls right out of the box.
TopScan Bluetooth Device Makes Error Code Diagnostics a Cinch at Home’ continued…
Derin Richardson is a seasoned editor who's worked in print and digital media since 2008. He earned his Bachelor of Arts at California State University, Fullerton, and is an avid fan of American muscle. He oversees content for LS1Tech, The Mustang Source, Mustang Forums, Dodge Forum, MB World, JK-Forum and 5Series.
As the grandson of a former L.A. Fire Department mechanic, he's grown up around cars and trucks most of his life. Some of his fondest memories are the times he helped wrench on his grandfather's 1941 Ford Pickup, which he endearingly nicknamed "High Yeller."
He currently drives a Red Hot 2018 Chevrolet Camaro SS but appreciates anything with four wheels and a little rumble.
Derin can be reached at derin.richardson@internetbrands.com
