Need Help !!! Something Doesnt add up
1998 forged 347ci LS1 motor
Texas Speed & Performance (TSP) lid With K&N Air Filter
Machine Ported throttle body
Hooker Ceramic Coated Long Tube Headers & Off-Road Y-Pipe w/cutout
LS6 Stage III Corvette Z06 ported heads
ported LS6 intake
UD pulley
Comp Cam X3-V2 606/608 112LSA, 236/240 camshaft
Comp Cam lifters
LS6 Oil Pump
Rollmaster Dual Roller Timing Chain
Scat Forged Connecting Rods
Mahle Forged Pistons
Hardened Pushrods
Stock balanced crankshaft
Flow-matched 42lb injectors
NX Nitrous system with the big selenoids with 4an lines nozzle system
Nitrous Outlet Dedicated Fuel System with 109 oct in it
Built 4L60E
Vigilante 4000 torque converter
Trans Go shift kit
B&M Aluminum Deep Oil Pan
Stock 10 bolt
3.73 Gears
Stock Suspension
QTP 27.5 X 11.5
Pro stars Drag Set up
We went to the Track and Of the Trailer we forgot to warm up the bottle and ran with a 125 Shot and Ran 11.01 at 121 with a 1.54 sixty then we Bump up the pills to 175 shot and the car only runs 10.81 at 124 with a 1.58 sixty. I figured that the car would have ran alot faster since this time around we shot 175 and we had the bottle pressure at 1000. What do you guys think I think there is something wrong and we should be running much faster I was hoping for 10.50s What do you guys think any suggestions?
Did you data log your run by chance?
What was the RPM's thru the traps at what mph, and what diameter tire are you running?
Calculate your driveline slippage, and I bet you find the answer.
Tire Size is 27.5 X 11.5
RPM was 6600
MPH was 123
how do you calculate the Slippage?
Take that #, divide it by 12 to get the rollout of the tire in feet.
Now, take the mph, and figure otu how many feet per hour that is (123 times 5280) and divide that by 60 to get the feet per minute.
Take the 6600 rpm, divide that by the rear end ratio, then take that # of axle rpm, figure out how many feet per minute the car should be going.
Divide the 2 and you get your slippage.
In your case:
123 mph = 10824 feet per minute
28 inch tire = 7.33 feet.
10824/7.33 = 1476.67 axle rpm @ 123 mph
6600 rpm divided by 3.73 = 1769.43 axle rpm
You are seeing 83% of what you should be seeing, therefore you have a 17% slippage.
You're definitely blowing thru something, either the converter, or the tranny is slipping. You should be seeing around 5 to 10%, even 10% is higher then I'd want to see.
From what you've already done, I'm guessing (and it's only guessing) that the car has a bottom 10 in it (say 10.2) without adding any more power, just by swapping to a TH400/good converter/strong rear that can take it.
Throw more power at it, take out some weight, and you will be headed to single digit territority, as long as your tuneup is good, you probably can do it if the car leaves hard enough and it's not too heavy. Just spraying right off the transbrake is going to make a huge gain, enough so that you're gonna need a full 28 inch slick, etc to get down.
Also, Vigilante converters are known for being alot looser than advertised. You're probably blowing through the converter like JL stated. Usually, a super loose converter + n20 = crappy ET and mph.
Best bet is to have one made, the gear ratio change, etc.etc. generally dictates needing something different.
My car is full weight cam only on the jug and my times were on par with yours with the same size shot you're running. I have a vig2800 and my slippage on the top end is right around 6%.
What kind of converter slippage are you seeing on motor? Not that it matters but what did the car make on the dyno?
Your set up sounds a lot like a friend of mines(Detroitmuscle) and he has run as quick as 11.30 @ 120 with a stock bottom end LS2 with a cam similar to yours, 5.3 heads, SS4000, LS6 intake, 3.23 10 bolt, @3700lbs ect..
