Stock Bottom End LS1 H/C 6.44@105 1/8th mile
#32
Could you PM what you did to get the car so light? I have a 2002 Camaro Z28 that weighs 3540lbs race weight. My best time so far has been a 10.39@129mph with a 1.41 60ft. I also have a th350 with a 4.11 rear gear. I just installed the antiroll in the rear so I am waiting on a test and tune night to finish setting up my suspension.. BTW my setup is a 402ci LS2, th350 tranny with a PTC 5000 stall that actually stalls to around 4600rpm, full suspension, Strange 12bolt.. Still have A/C, heat, full interior radio, speakers, etc. If I could get down to 3000lbs that would be some 9.70's -9.80's right there.. Thanks man..
#33
1 Post
https://ls1tech.com/forums/drag-raci...-progress.html
#34
I'm going to refer you to my build thread because that's a lot to type. I answered a couple of these similar questions in this thread and you will be able to see my total setup. Just remember that any post after the videos on the thread is additional weight that's being taken out but those are some good ideas. Sounds like you could use some weight reduction but a full weight car in the low 10's is no joke. How much power are you making? I plan on going 9.9 something next time out while still having lightweight carpet, full dash, door panels, rear interior panels, and a headliner. The car doesn't look as light as it is because the interior still looks in tact and that's how I will always have the car.
#35
Thanks for sharing.
Mike
#37
Fti stalls is where it's at.I just put a small 3600 in my car and it is unbelieveable.I got some prc 5.3 heads I was going to sell but after looking at this post they are going on my car.Awesome car you got there.
#40
1 Post
Thanks, I have a Mustang also that's getting a turbocharged 5.3. I could go faster on my Camaro's setup if I felt like cutting into it more but I want to keep it nice for some real heads up classes. However, my Mustang strictly going to be a "how fast can I go with a 5.3" setup. Good luck with your ride!
