Stock Bottom End LS1 H/C 6.44@105 1/8th mile
1 Post
Made some runs a couple of weeks ago in the 1/8th mile. Car has a stock bottom end (no rod bolts or flycutting) with an MS3, PRC 5.3 heads, and a 92mm FAST. The car weighs in at 3000 pounds plus has a 10pt cage with the start of a funny car cage. Still has interior panels, carpet, dash, etc.
http://www.youtube.com/watch?v=dGhR0WDcypY
http://www.youtube.com/watch?v=QIdFSPFH1DI
1 Post
Thanks, I need to get to a 1/4 mile track. It went a 1.39 60' off of the footbrake and a 1.37 60' with the two-step set at 4000. I'm moving it up to 4400 and trying it out this weekend. The 275 Hoosiers are working out very well.
that should be a 10.2 pass on 1/4 track
1 Post
Thanks! I'm amazed at what these little 346's can do! I'm waiting to put the spray on so I can make one of those bumper draggin vids like yours!
I agree, these radials weigh 11 pounds less (each) than my 295/55 MT Radial. I lost 22 pounds on tires that I needed to buy anyways.
1 Post
http://www.jegs.com/p/Hoosier/Hoosie...60685/10002/-1
1 Post
Got one pass in today due to the motor moving and ripping the bellow off of the airlid. Furthermore, I forgot to move my rev limiter up from 6600 and it hit the rev limiter before the finish. The car is now coming apart for the motor plate an other stuff. Went 10.31@127.9 so I'm thinking 20's shouldn't be a problem once its not running open throttle body and the motor is situated.
http://www.youtube.com/watch?v=mzYyD52r2ec
I've been debating doing the same heads and the MS3 on a 111LSA or a Tsunami on a 111Lsa Carbed LQ9 (Vic JR) on a 2980 lb G-Body with a powerglide. Would like to see the 10.60-10.20 Range. What trans are you running and what rear gear??
