Brian Tooley cam, stock LS1 241s, 175 shot - 10.01 @ 134
I would listen to whatever he says because he is way smarter than we are when it comes to this kind of stuff. I know since the cam is so big it really limits what you can do with the heads but he would definitely be the guy to listen to.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Sorry for the hijack. Figured I'd ask since so many were talking about this cam.
I am also looking at this cam or the stage 3. He recommended the Trick Flow as cast 220 (slightly touched by him) to me. Price was reasonable.
I'm having pretty good success with the 241s so I'm sure a set of 243s will flow a little better. The driveability is great also.
nice work man that thing is moveing out!!! I got a simliar build going on. I am also using Brian's stage 4 cam with a Nitrous outlet 90mm plate. I'm going with a set of AI heads so hopefully I can row my way to 9.99s!
Awesome setup! That cam seems similar to my Tsunami cam specs I believe? I would love to get similar times as you. I have 853 heads and stock ls1 intake. I am looking into some 243's or the RHS heads, and a better intake. Seems like the cam killed my low end, I think the 4.11's will help. Is this on a single stage 175? Also, what settings do you have on your Lingenfelter box? I am using the LNC-2000 as well. Again, awesome times!!
Running 3.75 gears
Yes, spraying off the line. Footbrake for now. I'll be working on getting the Tbrake hooked up and working in unison with everything else this summer.
Yes, single stage 175 shot out of the hole. Nitrous outlet dual stage plate but spraying it just on a single hit.
I'm pulling 4* on the 150 shot and 5* on the 175.
Thanks!
I appreciate it. As of now, the plan is to be at FL2K14. Make sure you come over and say hello.
I went ahead and put the Tooley stg 4 cam in mine this past weekend and it def woke the car up big time. Cant wait to see what it does, shooting for 10s on the motor before i put a 92mm plate kit on it.
The Car has an FTI converter in it but I am not sure its exact size. I will get with OP and have him answer these questions for you.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
