10 Second Club Now you are haulin! 10s are sweet
Stick Shift 99 Trans Am LS3 Stroker 10.859
Old Sep 3, 2022 | 12:05 PM
kmk9048's Avatar
Default Stick Shift 99 Trans Am LS3 Stroker 10.859
Figured I'd post this here since it went shockingly easily with the right-ish setup. Reached my goal of getting into the 10s all motor last night at Great Lakes Dragway in Union Grove, WI.
Car is a 99 trans am
-TSP LS3 stroker 416, 11.8:1 compression
-PRC 247 Cylinder heads
-251/258 duration cam
-Mamo FAST 102, ARH 2" headers to 3.5" Y dumped
-Monster LT1S clutch
-Stock T56
-Strange S60 rear with 4.10's and an strac.
-3650 pounds with me in it.
-Viking front and rear coil overs set to their base drag settings. 550lb front springs as this car also will get road race treatment eventually.
-93 Octane
-Mickey Thompson 3055S out back with the little guys up front.
Two Step was set to 3500 on this pass, just dumped it and changed gears when the shift light came on. After this, took my wife, dad and some family friends on a pass, went back to back to back to back 10.95-97's. Final pass was a 10.84 with just me in it, trying to see if we can get a 10.7 setting the step higher.
Super thrilled with the setup Vid below:
Old Sep 3, 2022 | 01:45 PM
Tuskyz28's Avatar
Yes and yes!! its hard out here on the pimps.
Old Sep 9, 2022 | 06:15 AM
Shadow02SS's Avatar
Congrats on the 10's, what did the car make for power?
Old Sep 9, 2022 | 12:59 PM
kmk9048's Avatar
600 to the tire. There is def more in it, but this is a street car first. So, getting the most out of what i have is jsut going to be fine tuning the suspension etc.
Old May 13, 2023 | 09:18 PM
kmk9048's Avatar
A little update for the post. Went back today with the following updates:
Crank scraper, Canton baffled pan, vacuum pump, added AC back and took off the air filter.
Set car up really soft this time, left at 5200 and ran a 10.55 at 128! Video below:
Going to sell the slicks and try for a 10 on street tires. Couldn't ask for more with this thing.
Old May 15, 2023 | 06:48 AM
Shadow02SS's Avatar
Nice what did it sixty foot on the 10.55 pass?
Old May 15, 2023 | 08:46 AM
kmk9048's Avatar
Slip below. I tried dialing it up a bit more on the two step, but the track was closing and i just spun the tires each time after hot lapping it 5 times in row. There was a bit of a head wind as well.
Old May 15, 2023 | 12:06 PM
ddnspider's Avatar
Love some quick stick shift passes with a true H pattern manual trans. Nice job!
Old May 19, 2023 | 05:57 AM
Shadow02SS's Avatar
Good times, what were you leaving on the two step rpm wise?
Old May 20, 2023 | 09:32 AM
kmk9048's Avatar
5200 on the two step. Went to 5400 and it spun but the tires were also probably too hot because I was hot lapping it.
