View Poll Results: What kind of tire is every one running at the track
Voters: 531. You may not vote on this poll
What tires are u all running......
#42
depends on whether i'm running NA or N20.... NA i like 26" ET Streets for the increased RPM...
28x10.5W ET Drags for running n2o since i was running out of gear prior to the end of the 1/4 on 26's...
#47
I am running 17in ET STreeet DRs on the street and Hoosier 27x11.5-15s at the track.
Until now I have ran most of the tires listed The 26x10.5-16 ET Streets wave like a bitch with my 3,800lbs car on top of them! Enough to almost tag the wall last time out.
The DRs are mounted and ready so I may make a few passes on them just to see. I am waiting on the Bogarts to show up before I can run the Hoosiers.
One of the Guys here just got a new set of the Hoosier DRs. I MUST say I am impressed with them so far. He is kicking 11.0x at the track last time out and we just found 20 more RWHP on his car We were 'Testing' his new tires on the street and I have to say WOW they hook!
BTW for those who may be interested. The 275/40-17 ET Street DRs are a FULL inch wider then the same size Nitto's
#56
I've run the Hoosier 335/35/17 DRs & run low 1.5 60's everytime (20+ passes). I've also made 4 passes on some Hoosier 27x11.5 15 QTPs and ran 1.48 60's. I made a few passes on the same size M/Ts & ran 1.6 60's. This is all launching at 1500rpm with a 3200 Pro Yank stall in a 4,000lb car. And I can tell you the QTPs are MUCH more stable on the big end than the M/Ts are at the same air pressure (~ 15 psi).
I will be running the QTPs in the near future when I get my D-1SC on the car.
