10 Second Club Now you are haulin! 10s are sweet
Who's in here running a 4L60E?
Old 05-18-2005, 10:52 AM
  #41
LETHLWPN's Avatar
Originally Posted by kcshaner
I just bought a 4L60E fully built and I hope to run a 10.20 or so and I am still worried about blowing it up.
I can relate. I am on my third 4L60E transmission! The forst was stock..imploded at 385 RWHP ..the second (modified)I just toasted the 3-4 clutch pack and the trust bearing and now I'm having a new bulletproof trans built by ATF of Davie, Florida. I expect to pick it up today !!
I have consistently run hi tens and short times on E.T Streets/ Skinnies in the 1.50-1.53 range. The track prep sucks IMO though , Moroso, Palm Beach,Florida
There is a host of quality hih perormanve transmission parts at www.transmissioncenter.net ..take a peek. They have ready built transmissions as well..Good People!!
Good Luck
Old 05-18-2005, 09:25 PM
  #42
Kolk1's Avatar
Originally Posted by Kolk1
Stock trans, stock stall, stock rear end, 1.63 60' and 11.3 @ 119. Only car i own.
Just pulled a 11.1 at 122 1.602 60', last night, just a little tuning differences. Still no problems with the stock trans and rear end. Im going to run this rear end and trans until they blow up. So ill keep you guys in touch.
Old 05-19-2005, 09:03 PM
  #43
cablebandit's Avatar
last weekend with Rock On 4l60 1.57 60' 10.16 @ 136...and stock rear with 3.73s
3800# raceweight and MT DRs 275/50/15
Old 05-24-2005, 08:43 AM
  #44
ragingWS6's Avatar
59,000 miles, probably 250+ passes, and running the stock stall for 30,000 miles and a Midwest 2800 then 3400 converter for the other 29,000 miles. No slipping, comes out of the hole decent (low 1.7 60fts.), and still runs great! When it does go, I am calling FLP and getting their 4L60E or I just might get a new stocker and throw a shift kit in it. I hear that the important things for this tranny are changing the fluid frequently (check) and when running an aftermarket stall, having a cooler (check), deep pan (check), and a shift kit to increase line pressure as it should be. No shift kit here, but on my next tranny, I will have one.
Old 05-27-2005, 01:13 PM
  #45
gator's 99TA's Avatar
10.95@ 119 (1.50) on a rebuilt 4L60e spray out of the hole, slicks, 4.10 gear, 120 NX shot (ran out of gearing). shifts just fine. changing out the fluids is a huge key.
Old 06-03-2005, 01:07 AM
  #46
WILWAXU's Avatar
Times are in my sig. Drive the car too much on the street for anything other than a 4L60E.
Old 02-09-2007, 10:26 PM
  #47
1bad408's Avatar
i build 4l60es and they can handle 700hp no problem For the last few years, I have been concentrating on the problems of 700R4's & 4L60E's, and have come up with some "solid" solutions. With the help of Trans-Go (Reprogramming kits, No Yo-Yo steel front pump rings, accumulation products, and technical knowledge), Borg Warner (Hi-Energy 3-4 clutches, & Hi-Energy 2-4 band), and General Motors (Viton seal for the input to output shaft, eliminating rear planet failure due to lack of lubrication, and their Turbulator low-drag steel & quick clutch release technology). I thank you.
If you are "tired" of the 1-2 part throttle (slam, bang, harsh, or violent) shifts of your present 700R4 & 4L60E transmission, then you will like my Performance oriented 700R4/4L60E's. They offer nice part throttle 1-2 & 2-3 accumulated shifts with the shifts getting firmer with more throttle.
All of these factors have contributed to these units holding up to 550-575 HP for the Street/Strip 700R4 & 4L60E and 625-650 HP for the "Limited" Street 700R4 & 4L60E, (that is with using a 10" or smaller diameter torque converter of high quality). These transmissions come with a one year warranty.
If you are looking at building this transmission 700R4/4L60E yourself or having a competent builder do it for you, then I offer a very complete rebuild kits. These kits use the same parts that I use in all of my Performance 700R4 & 4L60E buildups, including the Trans-Go Performance Shift kit with the "proven" accumulation setup.
And paying close attention to clearances & details, has given us have many vehicles in the 11's, a few in the 10's, a couple of high 9's, and the quickest/fastest is a 3,630 lbs w/driver street driven 2000 Firebird. He built the transmission himself using the Pro Street Performance Upgrade, and has run a best of a 5.78ET @121mph in the 1/8 mile, & a 9.36ET @144.6mph in the 1/4 mile. By the way his wife does the driving. Had over 300 passes when he had to replace the 3-4 clutch pack. This shows you what the transmission is capable of, so it can be done, and you can do it with the right parts & direction.
Old 02-10-2007, 08:29 AM
  #48
JaSSon's Avatar
Ive been running in the high 10s for awhile now with a 4l60e. Its been rebuilt by a local guy once. Best times in sig.
Old 02-12-2007, 08:56 PM
  #49
01_ram-air's Avatar
Do you use the corvette servos?
Old 02-12-2007, 08:58 PM
  #50
01_ram-air's Avatar
And I have a stock tranny with a tq converter, spray through the shifts. Have only had to replace the shift solenoids. Many mid 11 passes and a few low 11 sec passes. I've gone 1.5x 60' tons of times and 1.49 a couple.
Old 02-12-2007, 09:05 PM
  #51
97blkz's Avatar
I have a few 10 sec passes under my belt and love my trans!
Old 02-13-2007, 01:02 PM
  #52
WAHUSKER's Avatar
I put 2 full seasons on my 4L60E. (~100 passes with a cammed motor running low 12s, and 100 more with the blown stroker running 10s) I just pulled it to go thru it - nothin broke, just a PM thing. I have the Z paks, 5 gear front planetary, vacuum mod, a couple of "Speed Secrets" done to it, and I run Royal Purple.
Old 02-15-2007, 08:35 PM
  #53
BAM-BAM's Avatar
just a built 4l60e for me...3 years of summers at the track.....
Old 02-27-2007, 10:47 PM
  #54
Got Me SOM's Avatar
built Century tranny here, got it used from a friend . running it with a yank 3800 converter. so far so good.
I agree with changing fluids often. I had my stock trans in there for almost 30 k miles and it lasted cause i had a good trans cooler and transgo shift kit in it. I drove it normal on the street for the most part.
heat kills trannies. hoping this tranny lasts me a loooong time. Now i gotta do a rear before that goes.
Old 02-28-2007, 02:11 AM
  #55
jay_lt4's Avatar
built my own 4l60e here, with the correct parts it can handle 10's with no problems and last several years of street and track abuse
Old 03-16-2007, 03:17 PM
  #56
sks355's Avatar
I still running my stock tranny.. LOL but is it cryin.
Old 03-17-2007, 11:25 PM
  #57
TERMINAL VELOCITY's Avatar
Talk to chuck at FLT he has a wealth of info about 4l60s.
Quick Reply: Who's in here running a 4L60E?
