10 Second Club Now you are haulin! 10s are sweet
im finally going back to the track, care to guess
Old Jul 23, 2005 | 11:21 PM
SMOKIN01TA's Avatar
Default im finally going back to the track, care to guess
going to the track end of this coming week, i finally dusted of my skinnies and will be upgrading to some w's on the rear, got the new gears broke in, car is lighter, added a ewp and removed the belt which was worth quite a bit on the dyno, got the new tranny in, removed 5th and 6th which was 10lbs of rotating mass, proshifted the other 4 gears and removed some more weight.
hoping to go low 10.3's high 10.2 in 3000+da, last runs were +100ft
Old Jul 24, 2005 | 07:19 AM
02SOMWS6's Avatar
What are you running for a batt. I was thinking of running no belt then putting the belt back on on the return lane and charge from there back to the stageing lanes or pits. My fat pig is still full weight, thinking about pulling my a/c pump,condensor,lines, and power steering pump. Your car fly's already, it will run what you want.
Old Jul 24, 2005 | 12:46 PM
SMOKIN01TA's Avatar
im running a dynabatt, i have made multiple dyno pulls in a row without the belt on just to see what happend and never lost power so i figure i have more than enough power to crank her up at the burnoutbox make a pass idle on back to the trailer. i wont do this till the car is dialed in and read for this tho, i cant put my belt on and off like i used to in 2 seconds cause i have a pin on hood now. ive never made a pass without a belt before cause i didnt have a ewp till now, im anxious to see what happens
Old Jul 24, 2005 | 12:55 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
I say 10.40's in this heat. good luck.
Coach
Old Jul 24, 2005 | 01:06 PM
SMOKIN01TA's Avatar
Coach
yea, thats probably more realistic, but i figured if i hoped for higher it wouldn't be as disappointing
no updates from you latley coach, you been takin a race break latley
Old Jul 24, 2005 | 03:20 PM
The last 3 weekends the words is RAIN!!!!!!!!!!!!!
Coach
Old Jul 27, 2005 | 10:56 PM
SUX2BU's Avatar
Good luck!
I wanna throw on an EWP too but am going to wait till i move closer to my job. this being my daily driver and all.
Old Jul 28, 2005 | 05:35 PM
79ls1's Avatar
a daily driver without a/c and a radio and your worried about a ewp HA HA HA
Old Jul 28, 2005 | 08:10 PM
SUX2BU's Avatar
EWP don't last forever. so i'de rather wait till i have a 20 mile round trip a day rather than a 90 mile round trip.
Old Jul 28, 2005 | 08:18 PM
SMOKIN01TA's Avatar
well, the car for the most part is done for tomorrow, i changed the oil finally, changed out a blown shock, put new w tires on, put ds loop on, put tranny blanket somewhat on and took out the passenger seat, straped down the battery. now, time to see what this succa runs
Old Jul 28, 2005 | 08:29 PM
SUX2BU's Avatar
Have you weighed it after taking this last weight out?
Old Jul 28, 2005 | 08:31 PM
SMOKIN01TA's Avatar
should be 2980 or so like it was when i striped it out at the atlanta race
