11 Second Club Snake eyes are a good thing
Should be 11's when done
Old Sep 29, 2009 | 08:50 PM
99T/AMAN's Avatar
Default Should be 11's when done
I am swapping in a MS3 cam, doing a udp, p&p tb and maf, best time now is 12.4 with a 1.71 60'. Has PS lt's, ls6, ss3600, street tune with hp tuners, all UMI rear suspension, Nitto's DR's and still on a 2.73. What do you think it will run after cam and another tune??
Old Sep 30, 2009 | 02:20 PM
99T/AMAN's Avatar
anyone??
Old Sep 30, 2009 | 08:23 PM
speedshifterNC's Avatar
I'm guessing around 11.8 especially if you go with a lower gear
Old Oct 1, 2009 | 08:18 PM
SLP IROC-Z's Avatar
with better gears you probably would have been close to 11s before the cam
Old Oct 4, 2009 | 06:33 PM
slowlsx's Avatar
it will probably run worse if you dont swap gears... it will be a pig with that huge cam
Old Oct 8, 2009 | 09:02 PM
jcobra99's Avatar
Get some 3.73s and some M/T D/Rs and 11's shouldn't be a problem.
Old Oct 11, 2009 | 11:17 PM
0-60's Avatar
these guys arew stupid my car has the same **** and does 11.32 at 123.. on 150 kit.. u do a little bit better.. and i ALSO have an ms3 waiting to put in just spray it lol keep 273s only thing itll pick up is 60ft an mph.. 273s work well long long legs..
Old Oct 12, 2009 | 11:06 AM
Intercooler2's Avatar
It will be there. I did it with bolt-ons and raced a car on radials, MS4, 3.73's and no converter that bested me MPH with a 116 but ran a 12.2
Old Oct 13, 2009 | 06:28 PM
jcobra99's Avatar
Maybe yours does on a 150 SHOT a 150 shot of spray is a HUGGGGGGEE difference between an MS3 Cam. The only one sounding stupid in this tread is yourself. A 240ish cam with 2.73s will hold him back GREATLY. The last time i checked gears help out ET's a lot ESPICIALLY with a big cam.
99T/AMAN Go with some 3.73s and 11's will be no problem
Old Oct 13, 2009 | 07:16 PM
MurderedOut's Avatar
390s and restall to 4000 and youll be in the 11s now with traction. with the cam, youll be mid to low 11s with traction
Old Oct 13, 2009 | 08:17 PM
99T/AMAN's Avatar
I have drag radials and i might have a set of 3.42's that i will put in but i am not going to put anymore money into this rear, i would rather get a 12 bolt!!! As for the re-stall it's not going to happen, the ms3 makes the same power at 3,500 rpm as stock and pulls like crazy from there so why do you guys think it needs a bigger stall??? I am hoping for 11.8 or something right around there.
