New Best: Cam Only...10s getting close
Last time out back in Nov the car went a best of 11.370 @ 116.88mph with 3600lb race weight. So I went to MIR today, caught some great air!The changes I made from my last pass was that pulled little bit of weight out of the car, I lost around 50lbs lol, and I made a duct that attaches to FTRA. Race weight this time was 3525. I think it has some 11.0hs in it as it sits. Didn't run with rear 15s and 275/50s yet, hopefully I will go tomorrow with those on. Here are the 3 best passes, Let me know what you think.
-999 DA
60ft 1.507
330 4.535
1/8 7.068
MPH 96.17
1000 9.297
1/4 11.171
MPH 120.18
-1432 DA
60ft 1.486
330 4.499
1/8 7.038
MPH 95.50
1000 9.277
1/4 11.160
MPH 119.72
-1423 DA
60ft 1.478
330 4.485
1/8 7.018
MPH 95.77
1000 9.251
1/4 11.127
MPH 120.17
MODS:
Pacesetter long tubes
Pacesetter ory
Borla cat-back
Slp blackwing lid
160 stat
FTRA
Duct that attaches to FTRA
Ported throttle body
Ported ls6 intake manifold
Slp 85mm maf
March underdrive pulley
237/242 .605/.610 112lsa cam (ms3)
Stock 6spd/ 3.42 10bolt rear
FTI 4k stall
275/40/17 Mickey Thompson drag radials
Weld Draglite front runners
Qa1 coilovers w/ 300lb springs(at 12 clicks)
Slp boxed sfc
Spohn non-adj panhard bar
Stock torque arm
Stock lca's
-999 DA
60ft 1.507
330 4.535
1/8 7.068
MPH 96.17
1000 9.297
1/4 11.171
MPH 120.18
-1432 DA
60ft 1.486
330 4.499
1/8 7.038
MPH 95.50
1000 9.277
1/4 11.160
MPH 119.72
-1423 DA
60ft 1.478
330 4.485
1/8 7.018
MPH 95.77
1000 9.251
1/4 11.127
MPH 120.17
MODS:
Pacesetter ory
Borla cat-back
Slp blackwing lid
160 stat
FTRA
Slp 85mm maf
FTI 4k stall
Slp boxed sfc
Stock torque arm
Stock lca's
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
60'-1.560
330'-4.565
1/8-7.036
MPH-98.14
1000'-xxxx
1/4-11.024
MPH-122.88
Thats some nice 60's! I can't seem to get my 60's to come around for some reason all of the sudden guess I'll have to look at what's up with that. Here's one of my all motor passes to compare. Looks like mine is pulling pretty good on the other end and I'm at 3490lbs with driver and 1/4 tank
60'-1.560
330'-4.565
1/8-7.036
MPH-98.14
1000'-xxxx
1/4-11.024
MPH-122.88
60'-1.560
330'-4.565
1/8-7.036
MPH-98.14
1000'-xxxx
1/4-11.024
MPH-122.88
Matt
Thanks man! I'm slowly getting the weight down, now its at 3490lb with me. Trying to get it down to 3400-3450lb with me. Also I picked up some strange 10 way adj rear shocks. I could prob get a fast 90/90 set up but I'm not sure if I will see any gain from it. I know if I do I need to get some injectors too. Also I could prob ditch that crappy merge on the pacesetter ory and pick up couple ponys and maybe some ft-lb of tq.
If you don't mind me asking whats your 1/8th et and mph? I thinking I'm going to have to pull off a high 6.8 to low 6.9s to get a 10sec slip.
Also going to be throwing some 4.10s in. So maybe I can pick up little from that too.
I did change the valve springs and pushrods to work with the cam other than that the heads are 100% stock.I wish I could mill them,also would get them ported at the same time but I know the piston to valve clearance is all ready close. So there would be no point taking them off unless to change them for some aftermarket cnc heads.
The Fast will really help pick you up some. I picked up 17rwhp switching from a LS6 intake to a fast. My 1/8 mile e.t. was 6.97@98mph with the 1/4 mile at 10.90@123mph and a 1.47 60ft. A good running N/A car will normally see 25mph between the 1/8th and the 1/4 mile. My first 10 second pass I went 10.995@122.8mph with a 1.49 60ft
That isn't going to make a difference. It isn't an all out race car. I have the adjustable BMR torque arm in my car and it took me from 1.49 with the stock torque arm to a (best so far) 1.46 60ft.
