Getting closer to 10's....
Thinking the 10 bolt has finally had enough, no more drag strip til a 9" goes in..
Here's a pic and video.. Small cam, LT's and a 100 shot Nitrous outlet plate kit(wet), A4 3200 stall, 3:73 gears.
http://www.youtube.com/watch?v=TQgfHHcNhmY
Are you spraying off the line or do you have a window switch or a progessive controller helping you leave ?
I think a 150 hit will put in the 10's now !!
QA1 12 way adj shocks, Front(coilovers 315 lb springs) and rear(not coil over and unsure of spring rate), Spohn chassis mount T/A, BMR tubular Chrome moly LCA's, Spohn rear drag sway bar, Panhard. I was very happy with all the changes, car launches hard, level and straight every pass now. Too bad I don't trust the 10 bolt anymore.. Will have to wait and try for 10's til next year when I have a 9"...
Same car, but about 3 years ago.. Just to give you an idea of how the suspension changes, also, changed the launch.. Before and after..
That's an option also... Won't be doing anything til next spring.. Just a street car for the rest of the year..
