11's EPS 226/230 cam only
Went to MIR for test and tune 9-16-2011. Car mods as follows:
2002 Z/28 A4.
ARH headers w/oryp
Magnaflow quad tip catback, no cut out.
ASP pulley
EPS 226/230 114+3
Comp trunion kit
3600 Vig
Bogarts with MT drag radials
3.42 gears
Race weight ~3525-3550
Track was really crowded and I only got 3 runs in. First run I spun which didn't happen when the car was bolt on, it basically dead hooked before. Aired the tires down and did a bigger burnout and ran 11.94 @ 112.98 with a 1.66 60'. Third run I lowered the air pressure again and ran 11.83 @ 113.55 with a 1.62 60'. I think the car would have run 11.7x if I got another run in, but after waiting 1-1/2 hours in the staging lanes for my third pass I was done for the night.
Suspension mods are UMI control arms and bolt in sub frames. My buddy Larry did the tuning. I'm happy with the car. It drives like stock, has cold A/C. The good fall weather is almost here and I expect to knock a few tenths off my ET. Will post a time slip later.
2002 Z/28 A4.
ARH headers w/oryp
ASP pulley
EPS 226/230 114+3
Comp trunion kit
3600 Vig
3.42 gears
Well ,the plan was to get everybody together again this month, but I had a few set-backs myself ( I had gotten sick). Be on the lookout for mid- October. I should be back on my feet by then . I haven't made any changes since the last time. So hopefully the cooler temps could be a big help for all of us.
But 11.8 is pretty good for your setup. Grats on the 11's and good luck in the cooler fall air!
The trap seems ok to me considering the stock ls6 intake. Is your TB ported? If you get the chance, I would upgrade to a ported fast intake with throttle body and then get the car retuned. I'm betting you gain a solid 2mph in trap and drop at least .2 off your ET.
I see no reason why you can't run 11.5s when the really good air gets here. I had the opportunity to drive a vette with that cam, and even with stock gears, it pulls hard upstairs. It has a great idle also. I wish I had gone that route.
I went back to MIR to get a few more runs in on the new combination. The weather wasn't as good as the last time out but I still got a new best. Race weight 3525 lbs. with me in the car.
60' - 1.61
330 - 4.77
1/8 - 7.43
MPH - 91.30
1/4 - 11.74
MPH - 114.26
60' - 1.61
330 - 4.77
1/8 - 7.43
MPH - 91.30
1/4 - 11.74
MPH - 114.26
