11 Second Club Snake eyes are a good thing
11.78@124
Old Nov 12, 2011 | 06:03 PM
blackls1ta00's Avatar
Angry 11.78@124
i need to do alot to get to low 10s!
Old Nov 13, 2011 | 03:54 PM
s346k's Avatar
was that on motor?
Old Nov 13, 2011 | 04:15 PM
KevinR's Avatar
Your 60' is killing you.
Old Nov 13, 2011 | 05:24 PM
gs462's Avatar
124 is 10.80 MPH with a good 60 ft, you have a 10 second ride if you get it to hook up. Low 10s ya you have a way to go.
Old Nov 13, 2011 | 05:50 PM
no it was on a 100 shot,but i found out my drivers side 02 sensor wasnt working?wtf loss of 28% of power!i shudnt have ran with worn drag radials.
Old Nov 13, 2011 | 05:52 PM
you are right man,everytime i went to take off it wud spit and sputter then fall on its face im hoping because of the bad sensor.
Old Nov 14, 2011 | 02:18 PM
PBMGOAT04's Avatar
Good run..but the o2 data is ignored at WOT. So having a bad o2 doesnt effect your WOT performance.
Old Nov 14, 2011 | 03:43 PM
bjamick's Avatar
Hey man, don't worry I'm right there with ya. 11.4@126
Old Nov 14, 2011 | 05:13 PM
it does matter when your not taking off good and it spits and sputters!the car couldnt 60ft at all because of the sensor!it was falling on its face as i stated.i ran around 7 passes and the 60 fts were 1.99 to 2.3 so id say its not running right.
Old Nov 15, 2011 | 01:02 AM
BayAreaSS's Avatar
Wow something is seriously wrong if that was on a 100 shot. Hope you get it figured out. I wouldn't spray it again until the problem is fixed
Old Nov 15, 2011 | 06:24 AM
blk/slvr02ss's Avatar
W/ A 1.6 60 ft u will b well into the 10's !!!
Old Nov 15, 2011 | 04:01 PM
djfury05's Avatar
Even on motor you should be faster than that.. better start to checkin' things
Old Nov 15, 2011 | 05:39 PM
i agree it should run better than what i did on just motor,im hoping the bank one sensor fixes the spit and sputter off idle,then its getting dyno tuned,i appreciate the comments guys.
Old Nov 15, 2011 | 07:09 PM
red 95 t/a's Avatar
Thats some shitty times. Some thing is wrong. You need to get your car strieghted out on motor before you even spray it. Then make sure your Nitrous end is good. Like make sure your jetting is on. If you run it lean or rich that will also kill your et's. Were you spinning really bad?
You should def be high-mid 10s for your combo. Hope you get it sorted out.Plus make sure you get the car mechaniclly 100% before you make dyno appt, oor it will be a huge waste of you money
Old Nov 15, 2011 | 09:28 PM
thanks for the shitty comment.i never ran the car before and i wanted to get a baseline,but i know now theres bugs to be worked out.the car is running way too rich.the car would bog its getting too much fuel and the 02 sensors might have something to do with it.when it comes to the tuning i will have bryan herter dyno tune it for me.
Old Nov 16, 2011 | 04:12 PM
LSjim's Avatar
are you spraying out of the hole?? make sure your plugs are gapped for nitrous and don't worry about it we build them ourselves so we can fix them ourselves just takes time to get it right good luck
Old Nov 16, 2011 | 07:01 PM
the engine isnt running to its potential im trying to take one step at a time to get it figured out,hopefully soon.
Old Nov 16, 2011 | 09:28 PM
fergymoto's Avatar
Well done spinxy
Old Nov 17, 2011 | 10:47 AM
Originally Posted by fergymoto
Well done spinxy
mind your own business!!!
Old Nov 17, 2011 | 11:26 AM
HioSSilver's Avatar
I guess I'm in the same boat as you, times in the sig. ......but damn a 383 with a 100shot should be alot faster. I would think you should fo faster than 11.5's on motor.
