Trans Am 1/4 mile (Iceland)
just to join the 11 sec club Going for the Ten's next year..
1/4 Mile ET: 11.143
1/4 Mile MPH: 123.620
1/8 Mile ET: 7.183
1/8 Mile MPH: 99.560
0-60 Foot ET: 1.689
timeslip: http://www.dragtimes.com/Pontiac-Tra...lip-24626.html
http://www.youtube.com/watch?feature...&v=dVsT-a725lU
1/4 Mile ET: 11.143
1/8 Mile ET: 7.183
0-60 Foot ET: 1.689
1/4 Mile ET: 11.143
1/8 Mile ET: 7.183
0-60 Foot ET: 1.689
1/4 Mile ET: 11.143
1/8 Mile ET: 7.183
0-60 Foot ET: 1.689
your mods?
Thanks guys, drag radials, hoosier 26"
its a mild cam, spraying 200 shot, intake, aluminum flywheel + spec3, long tubes + full 3" exhaust, 4.10 gears(changing to 5th before end, kills the mph) racetronix fuel pump & harness, aem wb and HP tuners, thats the basics,
still abusing the 10 bolt housing(wrecked it couple of times ), i got a 9" im modifying to fit, going with 3.50 gears which i think is ideal for this power and hopefully will get me in the 10's.
David,
David,
this car is amazing.... i tuned it for him
it´s a stock LS1 whith stock 241´s heads driven 100.000 miles and a unknown mild cam it trapped 114-116mph NA on low 12´s on the 10bolts and 4.10 gears full weight car. good budget setup.
it will be curious to see the car whith stronger rear end, better gears and a good nitrous controller.
Baezi
GOOD ****.. im in the same boat you are.. running high 11's on motor and going to spray a 150 shot next time out and hope for 10's on drag radials. also in a red TA
whats your suspension setup? i couldn't get my 60fts lower then 1.888.. 4:30 gears on a 25" tall drag radial could be why
