11 Second Club Snake eyes are a good thing
in the 11's
Old Jul 14, 2013 | 12:51 PM
021le's Avatar
Default in the 11's
Second time to track with the combo
Here are the current mods.
Yank 4000 RPM stall converter
233/236 custom cam
tune
Hooker long tube headers
Underdrive crank pulley
MSD wires
egr/air delete
Optima red top battery
Intake lid with K&N air filter
Lanes true dual 3in exhaust with twister mufflers
Dr. Gas X pipe
Auburn locking rear end with 4:10 Richmond gears
Eibach 2 in. lowering springs
QA1 shocks
Drag bags in rear springs
Frame connectors
Baer Eradispeed rotors
18" Hitchcock Full House C5 wheels with 295/35/18 BFGoodrich drag radials.
best time.
1.76 60ft
7.61 1/8th
91.76 mph
11.82 et
116.01 mph
temp 86, da 2539, relative density 93%, humidity 37%
This was my second time to the track with this car. 295/35/18 bfg drag radial tires at 20psi.
How much faster can it go?
Old Jul 14, 2013 | 12:56 PM
high impact's Avatar
Do you have 853 or 241 heads? Comparing the DA, 60 foot time and mph in my opinion you definitely have a few more tenths in this combo. Improve your 60 foot and you will et a little better.
Old Jul 14, 2013 | 06:01 PM
021le's Avatar
stock 241
Old Aug 11, 2013 | 11:10 AM
021le's Avatar
Update
First time on weld rt-s 15/10 with 275/50-15 mt drag radials@15psi
1.64 60ft
7.51 1/8th
91.74 mph
11.71 1/4
118.08 mph
temp 78 relative density 94.21, 65% humidity da 2023
3600# with driver
would only hook launching from idle, Every time I would try and stall it up is would only cut a 1.9 or worse 60ft.
Old Aug 11, 2013 | 06:24 PM
Z28SteveA4's Avatar
since you dropped your car 2' do you have any other suspension components like adjustable torque arm, adjustable panhard bar or lower control arm to set your rear suspenion up? this is probably the cause or your spinning issue. the whole geometery of your rear is out of wack
Old Aug 12, 2013 | 12:37 PM
SOHCNightmare's Avatar
I'm wondering if that lowering kit is reducing weight transfer to the rear. Might be part of your traction issue.
Old Aug 12, 2013 | 12:57 PM
118 mph trap? Stock heads? NICE! Making decent power.
yep, time for rear suspension. Lca's, relocation brackets and adjustable arm. Set pinion angle to -2 degrees. Where are your shocks set? Ditch the front sway bar, loosen the front shocks and tighten the rear to 50-70% (6-8 clicks). You will have to play with settings a little but don't do too much at one time like I usually do - change one thing at a time. ;-) Get that thing hooking and you have a few more tenths in it. Then spray it and go mid tens! ;-)
Old Aug 12, 2013 | 06:01 PM
sabersaw30's Avatar
What is your race weight? That is strong pull mph from 1/8 to 1/4.
Old Aug 12, 2013 | 09:03 PM
021le's Avatar
stock 241 heads
3600# with me in it.
was running 15psi, is that a good pressure to run?
Old Aug 21, 2013 | 09:54 AM
Beave's Avatar
Damn dude! Your latest slip looks identical to mine in these type conditions (our humidity was 95% though) and I have ported dart heads. Strong running car you have there.
Old Aug 21, 2013 | 07:50 PM
021le's Avatar
thanks, still chipping away at it.
im new to these cars, this is my first ls1, and auto at that
Old Aug 27, 2013 | 07:48 PM
1Bad97WS-6's Avatar
Nice I had a SI LS1 with full exhaust/SS4000/273 gear/DR/HP tuners runniing 1.59-1.61 7.51-7.53@90 an 11.91-11.93@112. I think you can do a little better in 60ft. You leaving of Idle and flashing the converter or you stalling it up.. I noticed my best times was from flashing the converter..
Old Aug 28, 2013 | 06:20 PM
021le's Avatar
Only hooks leaving off idle and flooring it.
Every time I try and stall it breaks em loose. 1.9-2.1+
Old Sep 18, 2013 | 01:53 PM
cuci591's Avatar
Any Vids
Old Sep 18, 2013 | 06:02 PM
021le's Avatar
Originally Posted by cuci591
Any Vids
Ill try to get some this weekend.
hope it does not rain.
Old Sep 22, 2013 | 11:21 AM
021le's Avatar
Update
weld rt-s 15/10 with 275/50-15 mt drag radials@15psi, 18"s up front.
1.58 60ft
7.39 1/8th
92.90 mph
11.56 1/4
116.67 mph
temp 57 relative density 97.98, 77% humidity da 696
Old Sep 23, 2013 | 03:57 AM
LS1rob00's Avatar
Congrats on the new best, not bad for cam only.
