Can I hit 11s with my setup??
So I have a 99 ta ls1 a4 with current mods being installed right now. Really want to hit 11s whatcha think
3600 stall tci
Stock 243 heads with pep 650 spring kit
Ms4 cam
1 3/4 speed engineering LT headers
Speed engineering true duals
Comp cam pushrods
Ls7 lifters
Ngk tr55/msd conductors
Volant cold air intake
High volume oil pump
3.23 gears
Oem wheels zr1 rims with 285/35/19 pirelli sottozeros outback
Founders performance lca's and panhard relocation
Stock ls1 intake
3600 stall tci
Ms4 cam
Comp cam pushrods
Ls7 lifters
3.23 gears
Stock ls1 intake
3600 stall tci
Ms4 cam
Comp cam pushrods
Ls7 lifters
3.23 gears
Stock ls1 intake
3600 stall tci
Ms4 cam
Comp cam pushrods
Ls7 lifters
3.23 gears
Stock ls1 intake
As I was reading down your list heads/cam/stall /long tubes/decent stall I was thinking 11's sounded conservative - many cars make 11's stock internals never mind heads/cam but as I read on I have to say no not going to happen... Anyone looking to get et's out of a 4th gen should start with wheel tire combo to hook it , bad 60 foot bad pass...... 15" or 16" wheels with a good drag radial. A tire made for cornering with no sidewall has no chance of hooking a heads/cam/stall car. Then that ls1 intake is going to restrict your heads/cam.
I think you have already spent the money on a lot of the components needed to far exceed your goal but the devil is in the details , it has to hook , it has to have good match between components and then be tuned properly to take advantage of the properly matched components and then its up to weather and driver skill/knowledge. If your racing in florida or Denver etc.. high temps , high altitudes ,combination of both , high humidity etc... its going to make it more challenging so need more info on where and when your racing this car.
Ya I was sure hoping to make it into the 11s lol.
I'm in the metro Detroit area and hoping to get to the track in the next 3 weeks so should be 60s but unfortunately I'm tapped on money so this is the set up for now until I have money for intake it's my daily driver so ill mainly be messing around on the streets
I would try to rent or borrow some stock wheels with dr's from someone else from the board in your area , even if only for 2 or 3 passes , I have just seen so many threads "went to the track disappointed" and as I am opening the thread I am thinking is this going to be another modded car on street tires thread???? yup just about every time.
I don't think the LS1 intake will keep you out of the 11's its just not optimum to meet the breathing needs of a heads cam setup.
This is all getting tuned before racing it right ?
I have a set of stock wheels sounds like I just need to pick up a pair of dr's for them I just thought the stockers weren't wide enough even with radials. I'll pick up a LS6 here soon, it'll be getting trailored to motorcity speed for a dyno tune as soon as the install is finished this week.
you must think so since you posted in the 11 second forum lol
