Low lift truck cam daily n/a 11 sec Z28
Thanks for the kind words man. This car has always been such a strong runner I think I'll always keep it a simple n/a setup. I hope to see a small gain from the cam swap and then maybe I'll add some worked over 706 heads and do a little light dieting lol
Awesome results. I'm curious about the pressures, tires must be hooking well at 25 since you didn't go any lower, but I'm surprised since I usually run that on the street and drop down to 18 at the track.
Thanks! If you look closely at post #14 you can see the that the outer edge of the tire wasn't even on the ground lol. Next time out I'll try a few less psi and try to hit them a little harder
here's an old dyno of the btr stage III truck cam in an otherwise stock 02 LS1 Z28 with 3.73's in 3rd and the stock converter locked on a mustang dyno, I have another Data sheet somewhere with the conversion factor, lotsa tourqe with this cam in a stock 5.7 though I still need to try the 8714 to see where I gained and where I Lost
Hi that is of great interest to me I have exactly same cam a BTR stage 3 low lift truck cam in my LS1 here in Australia and Yesterday I purchased a SUM 8714 cam, its on it way from USA and now I read your post and you did exactly same. Let me know what you think of it, it will be a little while yet before I install mine. Did you get it on the dyno ??
Regards Tim
Regards Tim
Regards Tim
Regards Tim
Thanks, my BTR 219/224+3 cam (really a 216/221) made 356 rwhp at a low 5700 rpm on low octane which tuner thought was good. 100 rwhp up from stock. I started with around 253 rwhp (most Aussie LS1s are about that stock) and this with only a baby cam and bolts ons, so not too bad but don't like the drop in power after 5900.
I am really impressed with your results look forward to hearing how you go.
I had a look at the low lift high lift versions of the TSP stage 3 truck cam dynos on you tube today in a 5.3 LS,
There is only 13.7 rwhp (15% drivetrain loss M6) 9 rwkw between them and must rev higher to get it. I would like to know what difference that would make to times.
In this article Lunati’s Pochon is quoted as saying,
"At the track, 40 horsepower less will barely get you 1/10 of a second"
article
https://www.lsxmag.com/tech-stories/engine/understanding-ls-valvetrain-upgrades/
article
article
https://www.lsxmag.com/tech-stories/...rain-upgrades/[/QUOTE]
If that is true then the Texas speed off road y-pipe is worth 80hp haha
article
Yes I find it hard to believe also, I wish someone would chime in and tell us how much a HP increase (10,20,30,40, HP) typically makes in actual times in a LS1, the majority on forums measure success by dyno HP which doesnt always tell us where max benefit for dollar spent is, there is a law of diminishing returns at some point where the little more to be gained must be done at greater expense. It's good that people like yourself are posting times, helps more.
There are plenty of online calculators to try, I like the ones at Wallace Racing. Its a lot more than just the amount of peak hp added 10-20 ect, to see gains at the track, it matters more at what rpms those gains are seen, and most importantly how much time the car spends at those rpms when accelerating. I have a great stall converter that keeps my revs well above 5k for the entire run after the first 60 ft so the low end tourqey BTR cam was kinda wasted on my setup, hence why I chose a cam with more duration and overlap to better match my converter and rpm range
That is true, though I still think I'll see a decent gain under similar conditions just because those few extra horses I got from the 8714 over the BTR stage III truck cam will be in use during the entire run down the track at a higher RPM than where peak tourqe occurs with my setup. My butt dyno is already feeling the gains lol
*Off topic*
I usually use my high mileage 4.8 swapped camaro instead to sling pie on the weekends(tough job for any St. Louis Camaro haha the roads here are really really bad and there are hardly any 4th gens on the road around here anymore)
Anyways yes I want to love my n/a LS1 forever and it's super quick but Mrspider you are really whooing me with that rearmount build thread sir! I have already built the perfect reliable ride for a "sensible" rearmount that needs to work everyday and I think and you make me want to believe it will work! I've been trying to figure how I would fit stock z28 exhaust outlets and so I've been scribbling some blueprints with my crayons lol maybe I'll make another thread
Thanks I'm ready to see the results too! Unfortunately I wouldn't be able to get a comparable dyno pull with this converter as it is not the type you want to lock at Wot, so it will just be track times once I get it sorted. I'm dragging my feet anyways because the air has been so bad, I'm hoping for a night of at least no more than 500-800ft air density and below 80 degrees if possible but I race at gateway so i should lower my expectations lol
Did you use the LS6 springs with your BTR stage 3 truck cam? From what I've read lobes a fairly aggressive on this cam despite being low lift, I emailed BTR and they advised against 1.8 ratio rockers.
Regards
Tim
Regards
Tim
That BTR stage III truck cam is now spinning inside the 706 headed ls6 sprung flat top 5.3 that I slapped together for my 04' suburban with 4.10 gears and it couldn't be happier in there. Turned my truck into a rocketship!!!
That's what I'm hear for
