im in! n2o assisted...
but not quite.* i don't spray right out of the hole and not through the shifts.
best run of the night as follows-
60= 1.672
330= 4.626
1/8= 7.129
mph= 96.67
1000= 9.313
1/4= 11.155
mph= 122.48
that was the last run i got in, the other runs of the night were ALL low 11.2's and one other 11.17- all @ 122mph.
demonicbird00 was there as a witness, also ALOT of other f-bodies were there including 2 guys who owned v6's (one of the guys is the only person with one in the 12's i believe).
the runs were done on a tnt 150 shot, 950-1000psi bottle pressure. im running pumpgas, stock timing map and stock fuel map with 3% taken out- so it still has a little more in it when i can afford/have time to get it on a dyno. it is nice and fat right now according to the 02's and zero knock.
FULL modification list as follows- even the dumb ****!
- ! rear seats, front swaybar
- pacesetter lt's/ory/cutout
- lid, custom ram-air (cut scoops in hood latch platform)
- egr mod, 160 thermostat, fan switch, battery relocated to spare tire well
- shift kit, cooler, 3800 2.5str stall, window-welded stock trans mount
- stock sized (255/50/16) mickey thompson tires on back, stock wheels all around
- tnt f1 with accesories, msd digi. window switch, racetronix fuel pump.
- adj. panhard bar, weld in sfc's.
- HP tuners tuned by myself- both n/a and nitrous .bin's.
the plan for this year is get ls6 intake, maybe crank pulley, get rid of some weight, and put on a short belt when at the track. im looking for 10.90's this year- and 11.90's on the motor. WITH the 2.73's- i refuse to change them out. GM MUSCLE is proof that it can and will be done
thanks for reading, update my user status please
Congrats Nick.
ow BTW your talking about 12secondv6 (James) and little G (Craig) both have N/A v6s in the 13s and james is lowwww 12s w/ spray
-brandon
sooooooo- title change please?
-brandon
thing that sucks though is i have to add a 4-point to be able to run it now so that'll add weight and basically negate the weight reduction im doing now. im guessing the 4-point weighs like 60 lbs or so?
got the short belt today also
http://homepage.mac.com/stevestrzemp...Theater71.html
im in the far lane in the first race- the rest of the video is mostly of dsm's.
Congrats Nick.
-brandon
reading this post makes me want to get a 150 shot, was it wet or dry??
) are all out now. only things left are to locate a ls6 manifold and put it on, put the short belt on, pull the pass. seat and try it again to see if i can't get any better. im also going to stick it on a dyno and get the a/f flat soon- when i get time. im also going to get a chromoly rollbar installed sometime soon. so yeah, i have alot of work to do in the near future
i also need to get my 2nd to 3rd gear shift figured out with the window switch. it sprays twice in 2nd gear (the window switch shuts the nitrous off, the rpms drop and then it hits again, shuts off and then shifts- all in the matter of about 1.5 seconds). i think when i get that figured out my mph will go up a little bit, maybe gain et. a little bit also.
it is a tnt kit, duel fogger wet. 150hp rated at the wheels-
also thanks for the compliments
- but like normal im still not satisfied
60= 1.672
330= 4.626
1/8= 7.129
mph= 96.67
1000= 9.313
1/4= 11.155
mph= 122.48
Nice job and welcome. I ran the same MPH N/A but my best time last year was only a 11.49. Suspension upgrades should get me closer to the 10's as well.
i may not be able to run on sat now cause of work
-brandon
