11's w/ stock N/A M6 LS1--no heads, cam, or weight reduction?
#61
i know i am a little late for this conversation but for what it is worth and thats probly not much my very first time at the track i was running consistant 113-114 mph and 114.92 on my last pass of the night .....i just cant drive
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#62
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Originally Posted by austin21
i know i am a little late for this conversation but for what it is worth and thats probly not much my very first time at the track i was running consistant 113-114 mph and 114.92 on my last pass of the night .....i just cant drive ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#63
and you're back.....
SI (hell stock motor from TB to exhaust manifolds) and 123 mph here.........
then again, i'm not a M6 and the SI list is biased for NA only (bull crap rule, SI is SI). so, i don't count.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#64
Your driving has very little to do with trap speed,that is is basicly a constant - will only very one or two MPH tops.
OH and 1-2 mph is a good amount IMO. It is noticeable on the big end when its a close race. Atleast I can tell when I went racing against a GN 2 weeks ago. He was trapping 111mph and I was trapping 113. I could tell I started to pull away.
#65
then again, i'm not a M6 and the SI list is biased for NA only (bull crap rule, SI is SI). so, i don't count.![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
I have been looking for an old issue of Hot Rod that had the formula for calculating ones HP in relationship to weigh and trap speed. Hopefully, I can find it- think you will be susprised how much HP it takes to trap a 3600# car at 118 MPR.
#66
Originally Posted by Bitemark46
Actually you're wrong. In drag racing the key is to lay down the highest average rwhp during the whole run. If your shifts are slow you are giving up distance the car has to achieve a desired mph. If you shift like grandma your mph will not be as high as if someone would powershift during a run. Remember, it's momentum. If it slows down (aka nose dives during shifts) it has to make up that momentum it lost and make it up in a shorter distance. Plus driving has alot to do with mph. Shift points are key. You shift out of the cars powerband its not gonna make the mph. -Mark
Thank you for the drag racing insight. No more on this subject - we would only be beating a dead horse.
#67
#68
#69
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
"other than a 224/228 cam, 1.85 rockers, Z06 heads (lingenfelter machines these, right?), my car is SI too."
We call that a heads/cam car, and they are in the 450-500 rwhp range. Low 11/mid high 10 car. Add spray, low 10 high 9 car.
Please let us know when you're running 9's, otherwise your car is average for the mods you have.
#70
Originally Posted by 93_z28
it takes 461.64,but as people have repetedly told you in this thread "THESE ARE NOT FULL WEIGHT CARS"
@ 112.5.MPR To increase the MPR there needs to be additional HP - THE ET can be improved upon with additional mods to improve traction (launch). Question is were does that additional HP come from to produce 116-118 MPH if the car is SI?
This is just some food for though - your caculation of 461.64 is big HP NO! Now do the caluation on a 3200# car at 118 MPR. Do you think that HP number is realistic for SI cars?
#71
Rule of thumb is .10 ET .75 MPH for every 100# of weight reduction. So a bone strock 3700# F- Body runs approximately 13.30 @ 106 - with bolt ons + 35 rwhp HP gain = 12.95 @ 108. Now reduce the car weight to 3000# (huge weight reduction). Do the rule of thumb calculation - .75 x 6 (600 #) = 4.5 MPR with a gain of .6 ET. That puts the car in a ball park figure of 12.35 ET
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#72
wow! my almost bone stock (lid, k&n, FRA) running 17" 275/40/17 at all 4 corners w/ absolutely no weight reduction car ran 13.01 @ 108 mph in 1800' absolute altitude (hot, muggy July air). Mike Kleman (Rapid Motorsports) saw that happen. Corrected, it was much better.
Must be over 500 HP then.
I'm trying to figure out how an early 60's Vdub that I ran hit 11's at only 110 mph? It couldn't have anything to do w/ 60' and gearing, could it?
#74
Originally Posted by mattf2
Merry Christmas, I'll get back to this after Santa makes his visit.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#76
FWIW, it seems that production tolerances for GM aren't as close as they may be for other manufacturers. Where my bolt-on car only produced 341 rwhp, others have seen upper 360s and higher with similar mods.
I know it's difficult comparing dynos since there are so many variables that can produce different readings.
A friend has a bolt-on '98 TA that consistently traps 2 mph higher than mine, and has gone as fast as 115 without an ls6 intake. His car is full weight down to the spare and the jack. I would call bs if I didn't know the car...and the driver. He can powershift, I can't.
I do believe 11s are possible with a full weight car. Though mine hasn't come close, I believe that with a better 60' and a better driver, 12.2s would be possible from my car the way it sits. I guess mine probably weighs between 3700 and 3800 lbs with me in it. It does have 135k miles so I'm sure it's lost a little power over the years.
My times are in my sig.
