Best guess at my ET
Best guess at my ET
i hope its ok to post this? if not just delete it but i was just wondering...
with the mods in my sig ... what do you think i would be able to run with:
ET Streets--
Nitto 555r's--
ET Streets--
Nitto 555r's--
if you get the car to hook, which shouldnt be hard with your suspension but you definatly should have some kindof drag radial or slick, I dont see why you couldnt run mid 11's. What is your raceweight?
no idea the only thing i really have removed are the EGR/AIR and rear seats.. cause it is my DD right now..
but im hoping to get sum skinnies...what else could i do to lose some weight but still keep the car somewhat tolerable for DD..
i took out the spare tire/jack, front bumper supports, rear bumper supports, floor mats (for when i race), and front swaybar which to be honest, i couldnt tell much difference with it off. Thats like 100 lbs, and the skinnies save a TON of weight. If you can find a lighter 16 inch rim to put some Cheater slicks on, youll be like 150 lbs lighter. Mine weighs 3216 without me and like 1 gallon of gas in the tank (gas = 7lbs a gallon), and 3375 raceweight, so with rear seat delete and depending on your weight you should be right around there, and providing you hook at the line you should be 11.5's all day and in good weather (-1000Dens Alt), youl probably see 20's and 30's.
nicee .. and ya the jack and spare are already out..and i take out my floor mat when i race just because it seems to get in the way... soo ill get some skinnies and maybe take the supports out and see what i can do..
thanks for the help
thanks for the help
Ballin im goin to the track this weekend so we shall see... i think my header has a small leak hopefully that doesnt do anything...
but my friend is goin with me in his new 335i its got like some stage 2 tune with a race gas boost tune thing? new intake and such... its pretty quick hes beat some modded Mach 1's and a SS and my friends T/A...
it'll be interesting to see what he runs on race gas...but hes gotten too cocky its time to put him on his level
ok im PISSED.... i just got back from the track...
12.33=my best time.. WTF is something wrong? i mean it was my first time at the track and i know im not the best driver in the world but i can drive... wtf is goin on
i also couldnt get any traction i was running 275 nittos that had been left outside for almost a year.. so they didnt exactly stick... but still..
60 ft---1.89
1/8---7.97
1/4---12.33@113
i dono wats goin on?? i had it in OD not D does that matter??
60 ft---1.89
1/8---7.97
1/4---12.33@113
Your 60' is killing you! Nittos dont work well with a big stall.. Also your MPH is low do you have 2.73's? I know your sig says 3.23's are you sure about that?
I have a 224 cam with PP LS6 stgII heads and a yank ss3600. Running MT drag radials 275/40/17 and 3.73 gears
60ft 1.57
330 4.711
1/8 7.357
MPH 92.655
1/4 11.588
MPH 116.93
60ft 1.57
330 4.711
1/8 7.357
MPH 92.655
1/4 11.588
MPH 116.93
What tire pressure are you running wws699? I had that same cam and the best I could get was a 12.3 @ 111. Similar setup except I'm a m6 w/ moser 12bolt 3.73's and ls7 clutch. I have heard a ton of negative things about nitto's. I ran that on the ls1 intake also, now I'm in the process of getting my 90/90 on.
60ft 1.57
330 4.711
1/8 7.357
MPH 92.655
1/4 11.588
MPH 116.93
60ft 1.57
330 4.711
1/8 7.357
MPH 92.655
1/4 11.588
MPH 116.93
im almost positive it has 3.23 gears and i was running 20 psi in the tires and 15 psi in the drag bag.. or w/e its called...
i could not launch for ****... if i gave it even 1/2 throttle i was spinning a lil...
if its just my 60ft and i need new tires then im happy but i feel like even with that shitty 60ft it shoulda been atleast a lil faster..
