Cam Only 12.2 at 118
Mods are in the sig... Last Night of New England Dragway
1st run street tires 315 sumitios
60'.....2.1
1/8....8.566
mph...88.89
1/4....12.92
mph...115.31
Nitto DRS on 16s
1st run
60'.....2.1
1/8....8.355
mph...90.93
1/4....12.62
mph...118.32
2nd run
60'....2.0
1/8....8.156
mph...91.45
1/4....12.42
mph...116.68
3rd final run
60'....1.9
1/8....8.00
mph...91.94
1/4....12.24
mph...117.64
not bad for cam only tune is perfect at wot but down low its still a little on the rich side
60'.....2.1
1/8....8.566
mph...88.89
1/4....12.92
mph...115.31
Nitto DRS on 16s
1st run
60'.....2.1
1/8....8.355
mph...90.93
1/4....12.62
mph...118.32
2nd run
60'....2.0
1/8....8.156
mph...91.45
1/4....12.42
mph...116.68
3rd final run
60'....1.9
1/8....8.00
mph...91.94
1/4....12.24
mph...117.64
So people don't settle for shitty times, when they have so much potential. I've never said anything too out of the way to you, though I probably could.
I mean, do you think that 12.2 is good for what this guy has? He seems to think so. He has decent tires but isn't cutting good 60s but the time isn't that good even considering the 60'.
well, all I have to say is he has the MPH there to go mid 11's with a good short time. All he needs to do is get it hooked up and that car will be on its way to mid 11's.......
You should easily be able to do 1.7s or better on Nittos, and that would land you 11s.
You're right about the Nitto's though, I cut a 1.68 at the 1/8th mile last Thursday with a 3000 Circle D stall converter. Stock manifolds, stock exhaust, stock 3.23 gears. Anybody that knows about drag racing obviously knows that the ET isn't good for the mph. But you don't know the op's background maybe he has only been to the track twice and this was his first time on drag radials. A lot of us don't go to the track a 100 times a year.
Thats a goood mph and with a little better 60ft you'll be in the 11's. Looks like your car runs good congrats
yes first time running drag radials and was getting used to launching ..4 time being at the track too i only got in 3 runs with them and the night was over...i was leaving around 1500 to 2000 rpms and was spinning a little out of the hole and it was pretty cold out for the track you can hear tires screaming down the track......and want the 10bolt to live a little bit longer also ...4.10s and 10bolt...ticking time bomb from a dead stop and drs
