12 Second Club In the 12s yet? Come inside!
Got the 12's not so happy about it though
Old 10-01-2010, 09:50 AM
somZ2801's Avatar
Default Got the 12's not so happy about it though
Well I have an 01 Z28 M6 with a catback ,lid and SLP UD pulley and 100 shot. I had it dynoed and it put just under 430 to the ground 428 Hp . hopeing for low 12's maybe high 11's I went to the track . Well I ran a 12.9 @ 115 with a 2.6 60 ft this was my best 60 of the whole night My worst being 5.1 . I can't get this bitch to 60 to save my life spinning to 3ed sucks. I think I need some differnt tires I am rolling on chrome 18 in. C-5 Z06 rims with a 285/35/18 street tires on the rear I hook alright on the street but not at the track at all so I am going to get some Et streets I think. so I am a little sad about the 12.9 .
Old 10-01-2010, 10:02 AM
RedRocketZ28's Avatar
When you do start spraying?
Old 10-01-2010, 11:12 AM
FASTEDDIE Z's Avatar
Yeah , some tires and some traction will put you in the 11's ,,no problem . Even with a 2.0 60 ft you would be @11.9 -12.0
Old 10-01-2010, 02:10 PM
somZ2801's Avatar
I have a MSD digital window switch and I had it set to come on at 2900 for this run but I adj. it down to 2500 and all the way up to 4400 in the 10 runs I got in and I just couldn't hook It was not just the nitrouis I just have no traction on motor alone at the track.
Old 10-01-2010, 03:09 PM
What gear did you activiate it in? I don't have mine come on until 2nd gear. 1st gear already spins bad enough off the bottle. Also, I wouldn't have it coming on below 3000 RPM. Could seriously hurt the motor.
Old 10-01-2010, 03:43 PM
somZ2801's Avatar
it is set off of a WOT switch which activates the MSD window switch that gives the relay a ground at set rpm that kicks on the soilinoids and it starts spraying.It is when I go WOT I dont have a progressive controller to make it actuate in second.
Old 10-01-2010, 04:49 PM
Nemesis350's Avatar
Yeah.... that 60ft is sooooooooooooooooo killing you. et streets sounds like the solution to your problems... but with an 18" wheel it still may be a little too rigid to hook "good".
Old 10-01-2010, 07:11 PM
somZ2801's Avatar
I have a set of 16 stock 98 z28 rims I think I am going to get a tire to fit those
Old 10-01-2010, 07:41 PM
Nemesis350's Avatar
That'll work! I'm sure you'll get a hell of a better time
Old 10-04-2010, 11:39 AM
disc0monkey's Avatar
i would raise the rpm window so you get traction before the n20 hits.
