Made it into the 12s
I ran the car when it was stock and on street tires, and it ran a 13.8 @ 102.2. I knew that was a little on the slow side, even being an automatic, so I went into the runs last night hoping to just break out of the 13s.
I treated my first run as a shakedown, and just rolled into WOT from idle and ran a 13.25@108.7 with a 2.2 60'.
I knew there was room for improvement because of my high 60', but I wasn't sure if it would be enough to break into the 12s or not. So I lined up again and did some testing with stalling up before my launch for the rest of the runs.
That's all it took, and I was into the 12s for the rest of the night.
Second Run: 12.98 @ 108.2
Third Run: 12.93 @ 108.9
Fourth Run: 12.97 @ 108.5
After the fourth run me and some buddies started adjusting my tire pressure because I ended up starting to spin on the fourth run. Aired the front tires up to around 42 psi, and bled the rears down to 22 psi. We also pulled out my passenger seat to see what would happen.
Fifth Run: 12.88 @ 108.7 (Best of the night)
Sixth Run: 12.89 @ 108.8
My friend shot some video from our phones. We ended up not being able to see the boards, so I added in the times before uploading the video.
http://youtu.be/DX_a1fayhLA
It was a great night. Broke my car farther into the 12s than I thought it would go, didn't break anything, and got some video and plenty of time slips. Glad to make it into the 12 second club.
~Andy
EDIT: Didn't see your sig. You already have DR's. That's the NT05's are my next tire after my 555R's wear out.
In between the stall/cooler and H/C/I swap I gotta get some cash together for a 12-bolt and 3.73s (hopefully before I blow the 10-bolt). Also planning on having my rear wheels widened to fit 315 NT05r's when my current set wears out.
Definitely trying to get mid to low 12s by the end of this season, and into the 11s next year.
60' 1.94
330 5.52
1/8 8.42
MPH 84.75
1000 10.92
1/4 13.00
MPH 108.70
Still on stock 2.73 gears. Have a set of 4.10's ready to go in
DA was at 1700 ft when i ran there on the 2nd
And yeah the DA was still up pretty good, even with the temps in the low 70s. Think it was still around 1250-1300 by the time the track shut down. If I made the same passes in october I might have hit 12.7x
