14.080 @ 108.63MPH what am i capable of !? !
try to get through the first 60ft as fast as you can without spinning the tires and raise the shift point closer to 6k. As far as everybody saying what you should run, or could run on street tires, most of the time thats BS. Not all tracks are prepped equally or even prepped at all. 2.1-2.2 60' time seems to be OK for a shitty unprepped track. Of course you want to shoot for better than that but dont go expecting what people post (usually their best) on the internet at different tracks and think thats normal.
on street tires i would realistically expect you to run 13.4-13.2 with that 106mph trap speed. There are people that can hit 12's with it, but that requires help in other places.
Remember this thread is titled "14.0 @108.63 what am I capable of ?" he is capable of 12's with that trap , he will need tires to get there but is capable of 12's.
Getting the hole-shot by a FWD car means you need better tire!
Build a secondary engine on a stand, means you'll be able to take your time and get the parts you need without rushing to get it done. There were so many things I would have done differently on my own engine build if I'd have had a secondary motor to just do it all in my own time instead of reaching some type of deadline.
I would agree with you if he were trapping 106 but he is close to 109 heck my fwd buick daily driver has run 13.1 on a 109 trap and fwd is a lot harder to hook up since the weight is transferring off the driven wheels instead of onto the driven wheels.
his original POST says he trapped 106 so i was going by that. My post was more realistic and directed as the car sits. not throwing more money at it towards tires.
again as far as your buick goes, that cant really be used as a direct comparison if it wasnt at the same track or similar conditions. we dont know the level of prep or lack of traction available at OP's track.
ok assuming he named the thread with 108.63 in error and going by the first post , I went back and see he did say 106 you are correct on that again personal experience rather than internet guessing I had a small block nova that ran 12.5 on a 106 trap.
Maybe he could borrow a pair of dr's for a pass that way he wouldnt be spending $$ I have loaned mine out at the track before to help people realize their potential . 2.6 60 foot times shouldnt happen on any tire but thats what he got and that is why his et was so terrible . I imagine he started this thread in hopes of getting input/ideas to improve his situation.How about removing the front sway bar , plenty of advice we can give to help him out.
I dont like to argue but just cant agree that a car trapping that well should be stuck in the 13's and I dont see many other people in this thread saying he should only be capable of 13's with that trap.
I respect you having your own opinion and agree if he doesnt do aything to improve his traction he will likely be stuck in the 13's thats about as close to agreement as we can come I guess.
Ran My 98 Z28 last week and got a 14.080 @ 106mph with rev limiter set at 5500rpm . R/T.197 60FT 2.686
WHAT AM I CAPABLE OF ??
CAR IS @ 175XXX MILES STOCK MOTOR . STOCK EXAUST ,CATS AND A CUT OUT . HYPERTECH TUNER , K&N COLD AIR INTAKE KIT , 4.10 GEARS , C5 RIMS WITH 265/40/18 CONTINETAL EXTREME CONTACT DW TUNED TIRES
http://youtu.be/IkBHyZPJ3lA?t=10s
#32
OP heres some facts that might help figure what your car is capable of.
My car with bolt ons, stock stall, 3.23, and street tires...
13.197 @ 106.93 with 2.092 60' in 2265 da.
Same car...
13.087 @ 106.87 with 2.018 60' in 2062 da.
Addition off drag radials and good da...
12.740 @ 109.22 with 1.963 60' in -249 da.
Same car in cold da...
12.638 @ 110.04 with 1.958 60' in -1245 da.
And thats all the saved data I have when my car was bolt on only, full weight, and stock stall. Also, the car did not have a good tune.
Things that come to mind for you...
The only time you should go to the track with street tires is when you want to have fun, not to expect a great 60'.
Those 4.10s are just silly on top of street tires lol.
Get yourself some good drs and report back
Same car...
#33
yeah 4.10s are overkill in a street car especially a dd street car. on street tires with that gear is going to spin. i would do a few things that are cheap i did to my car that helped alot. torque arm lcas and lca relocation brackets. if your going to run on street tires drop the air pressure to 22-25 psi will help, or get a good set of drag radials. if you looking for a cheaper set the nittos work great. id stay away from the bfgs they suck in wet conditions. but mickey thompson or hoosier are the best you can buy but are 200 plus a tire. you can get nittos from discount tire direct heat cycled for 170 per tire
#37
#38
its not the motor his trap speed is 108 same as mine and i have just longtubes lid and tune. suspesion and tires is the way to go i ran a 12.7 at 108 with drag radials and full suspension.
#39
also on street tires drive around the water and warm up the tires. dont go through the water. street tires are designed to push water away from the tire and it throws it up in the fender well and when you pull up to the line it drips back onto the tires making them spin when you leave. also drop the air pressure between 25 to 30psi. if you want more help pm me. everyone on here swears you need 1000hp to make quick times and its simply not true. ive raced for years and a car that can but the power down will be the victor. cause spinning aint winning
