12 Second Club In the 12s yet? Come inside!
new pb time
Old Mar 23, 2014 | 05:26 PM
Gotit4cheap16's Avatar
Mods are:
Slp lid
Smooth below
Nitto nt555r on 17 inch wheels
Hand ported tb
Ls6 intake
Hooker headers
Tsp offroad y pipe
Slp lm1 exhaust
3.73 gears
3700 ptc stall
Dyno tune
341rwhp 344rwtq
It was cold at the track and everytime I left hard I spun so I left easy on this 12.6 run. I believe I can get a 12.3 or 12.4 out of the car.
Old Mar 23, 2014 | 05:33 PM
HCI2000SS's Avatar
1.7 60ft with Nitto dr's is pretty good regardless lol! Nice job
Old Mar 23, 2014 | 06:49 PM
LS1rob00's Avatar
Agreed! Haha I think the 555R's are just a glorified street tire (and I've had a few sets).
Car should be able to do some mid-low 1.6's with your setup if you can hook and that's right on par with that 12.3/4 that you want. Mph seems a bit low to me though for the mods, even being an auto. I would think the car should be doing at least 110mph.
Old Mar 23, 2014 | 06:58 PM
Thanks guys. I too was wondering why my mph didnt go up.
Old Mar 23, 2014 | 07:08 PM
98CayenneT/A's Avatar
Did you flash the converter or stall it up a bit? I'm also a A4, had 2.73s, pretty much same mods and ran almost the same time as you, now I have 3.73s, no time slip with them but also plan on stalling my car this spring, so your times have been fun to follow, will also be going to a 17in wheel and think I will try the toyo proxy drag radial
Old Mar 23, 2014 | 08:20 PM
I stalled it up a bit and launched. I could only stall it at low rpms without spinning. I had the nittos at 30psi....maybe I should have tried 25....
Old Mar 23, 2014 | 08:42 PM
LS1rob00's Avatar
30psi wtf?
Lol that was a huge part of your problem hooking up. Bring them down to 19psi and then move up or down from there depending if you hook or not. 30psi is what you should be running on the street lol. Did you do a burnout?
Old Mar 24, 2014 | 01:47 AM
Oh ok. Yes I did a burnout and heated the tires up good for the 12.6 pass. I will definitely put them at 19psi or lower next rime I go to the track which wont be till the weather starts to hit 70s and 80 degrees.
Old Mar 29, 2014 | 11:50 AM
sabersaw30's Avatar
Take them down to 15 then do your burnout that will put some air back in tires you should hook good then. I pulled a 1.62 on mine. I am running a 8inch wide 15 rims too so got alot of sidewall hanging off.
Old Mar 29, 2014 | 08:08 PM
murphinator's Avatar
cars run slower when it gets warmer , Density altitude is huge in getting good et's out of any platform
Old Mar 30, 2014 | 08:20 AM
Holloway5's Avatar
^ What this guy said. Running with a bit chillier temps will result in better time.
