12.9 i made it to 12's
best last night was 12.734 @110.9 1.998 60' ...... I think the track went to junk fast cuz I spun reel hard on the next pass. it was truck night so I figure the offroad tires were killing the track. 12.6 is so close but the weathers about to get hot so idk if i'll make it.
I don't think he needs mickeys, a lot of ppl instantly put those on their car but they are HEAVY. It will probably slow down compared to the other passes you hooked. I had good results with toyo tq's they are softer compound than the nittos. Hoosier DR's would be my recommendation though. Light and hook
I went out last night and played with tire psi and burnout times was able to get 1.9's, so will see if it stays consistent. last pass I hit 12.76 @106 on the brakes (bracket racing) with I would have stayed in it. just got lca relocation brackets, and hopefully will have a ssra installed by next week.
what brand exhaust is that? How did the install go?
And Spicebird, I didn't realize the weight difference between Hoosiers and M/T's. I will have to seriously consider switching. I see comments of 8 - 10 pounds per tire.
