12 Second Club In the 12s yet? Come inside!
Any one running 12's w/ 10 bolt
Old 02-11-2005, 09:33 AM
  #41
fff
fff's Avatar
10 bolt, 4.10 gears and stock tires...best 60 was 1.9. Times in signature. This was my first time at the track. I plan on trying to break the 10 bolt this year
Old 02-11-2005, 12:16 PM
  #42
Chris81's Avatar
In sig..
80k car, 25k on the clutch.. 5000+ rpm clutch slips .. best 60' to date is a 1.81 on 255/50/16 BFG's, bad DA and not the best track. No good times with the LS6 cam yet, most likely a set of 4.10's is next.
Old 02-15-2005, 11:00 PM
  #43
sleeperstyle's Avatar
12.8 @ 107mph, 2.73's and nitto's on the 10 bolt. not as worried because i have the 2.73's though.
i've heard 10-bolts CAN last ok with an auto as long as you are not lifting the tires or anything in that power range.
Old 02-18-2005, 08:00 AM
  #44
Mac 2002 SS's Avatar
Originally Posted by 00Z28 Camaro
any of you guys running 12's with the 10 bolt ??
Stock 10 bolt here with stock gears (3.23) .
ET and mods are in the sig .
Old 02-18-2005, 05:37 PM
  #45
MyCarIsSLow's Avatar
We'll hopefully see about that soon
Old 02-22-2005, 01:22 AM
  #46
6spdpewterZ's Avatar
Originally Posted by Formula94
Reaction time has NO BEARING WHATSOEVER ON ET!!!!! All it measures is the amount of time from when the green light flashes until the clock starts. The clock doesn't start until you start moving, so you could sit at the line for 5 minutes after the green light flashes and still run your 12.8@110.
Old 03-02-2005, 07:39 PM
  #47
tomss99's Avatar
11.734 with a 1.751 60 at 117.84 10 bolt.... et streets.... just cant drop the clutch...slip that sucker....
Old 03-13-2005, 04:55 PM
  #48
One Bad Z's Avatar
I have two friends that have run mid 10s for the past two years with 10bolt.
Old 03-13-2005, 06:11 PM
  #49
BriancWS6's Avatar
12s here as well.
Old 03-16-2005, 01:08 PM
  #50
aliwantsnss's Avatar
My car went 12.2 @ 114 on my stock 10 bolt, with a 1.8 60ft, and BFG DRs.
Old 03-16-2005, 05:18 PM
  #51
LS1PoweredZ28's Avatar
I ran the time in my sig on my stock 10-bolt. I was praying the entire way down the track.
Kevin
Old 03-16-2005, 09:25 PM
  #52
rtr2001ss's Avatar
12's also. No sign of any problems yet. (K.O.W.)
Old 03-17-2005, 02:24 PM
  #53
WS6HUMMER's Avatar
I am but not for much longer.
Old 03-18-2005, 11:25 AM
  #54
LTwonZ's Avatar
I ran a 12.6@113mph when I blew my tranny. I've have ran plenty of 12.6-12.8's with the car.
Old 03-18-2005, 12:18 PM
  #55
ONGRNGO's Avatar
I made it to 12.30s, then Boom there goes the 10Bolt , That was on 275/40/17 Nittos cutting low to mid 1.8 60fts, launching at 3000 to 3500. But I am excited to get the 9" in and launch at 5500rpm with slicks
Dan
Old 03-29-2005, 08:37 AM
  #56
Unstang's Avatar
11.72 with a 1.71 60' time is my best so far, (12s on the motor though) should be a bit better with the new cam.
58k mile '98 Z, 3.23s, A4 w/ 3200 2.8 STR Yank.
Old 03-30-2005, 02:13 AM
  #57
tomss99's Avatar
12.004 at 115.89 with a 1.936 60 sliippin the clutch too much... 404 rwhp car untuned... wooowee so close but no cigar for the 11s.... 11s that is in full street trim...
Old 03-30-2005, 06:42 PM
  #58
Moderator
davered00ss's Avatar
Yes and I know people in the 11's w/ 10 bolt.
Old 03-30-2005, 09:28 PM
  #59
SSilverSSurfer's Avatar
12.60 w/ my mods
Old 04-04-2005, 12:12 PM
  #60
Racin'96 SS's Avatar
Ran many passes in the 12's with stock rear/3.23/TA Cover. No prolems yet..A4/ Vig.
hoping for 1 more season outta it...get married and that has all my money tied up so it has to last this year.
Quick Reply: Any one running 12's w/ 10 bolt
