what do you think
do you have the stock rear/clutch?
-Brandon
on DRs ive been launching at 4k SLIPPING the CLUTCH out and netting 1.8s consistant
dont Dump the clutch or youll snap the rear
heat the DRs up good start the tire pressure at 20 psi then go from there shift at 6k
on the 1-2 shift, shift at 5600 or so cause the stock tach in first gear at WOT is off
so when you shift there, the real rpms should be around 6k
good luck
Brandon
