I made it....
1st pass
r/t .346
60' 2.146
330 5.602
1/8 8.390 @ 87.72
1000 10.794
1/4 @ 12.800 @ 112.93
2nd pass
R/t .602
60' 2.139
330 5.623
1/8 8.425 @ 87.33
1000 10.840
1/4 12.850 @ 112.82
3rd was same but 12.847@ 112.99
I have basicly no mods done But i was on DR and using 150 Dry Shoot
Is this ok for what i have done or no my 60ft times sucks any ideas?
Its a 98 Black Formula A4. Well atleast i made it So atleast i'm kinda happy
Your 60's could use some help. At what point do you begin spraying, do you have a window switch if so where is it set? Is this a wet or dry shot?
you said it.. so did he
Do you have any runs without the nitrous? Trapping 113 (essentially) in a 98 A4 with no other mods indicates that you have the power you should from the nitrous, and you should be closer to mid 12's if you get the 60's down.
What was the bottle pressure at? Is it a NOS 5177?
Have you had any tuning done, or hooked it up to a scanner/autotap/wideband O2?
), you have an A4 and should be hooking up betting than that. I think with 2.0 60ft, a good tune, and a stall converter, you will be very very pleased!
