ran a 12.7!!!
0 Yes. 5 rwhp = not a snowballs chance in you know where.
Very controversial as to any real gains, may even show negative numbers due to the fact it will be tricking the computer to run lean due to the larger diameter of the housing (good for stock, since you will gain a few hp by running a little leaner than the factory slightly rich setting; however, bad for modified vehicles). Stock MAF's are good to 500+hp. Once you are beyond that I suggest you contact your tuner (or local speed shop if you are doing your own) to find out what they recomend. Some will suggest taking the maf out and doing a speed density tune, which relies solely on the front O2 sensors.
Maybe for a loudmouth or cutout but not for the flowmaster. Do a search and you'll see that you bought the absolute worst flowing catback on the market. Less flow = less HP.
I'll give you 5.
Didn't you say the car wasn't tuned? Only torque management removed if I remember correctly.
98 fbody + 25 rwhp + 2.73 + stock stall + KDWS does NOT = 12.7 @ 109. No way, no how.
Either your car didn't run that time, the tracks equipment was off or your car has more done to it then we are being told.
mods are
02 z28
slp lid
ftra
pacesettel longtubues,ory pipe
magnaflow dumped
2.73
275/40/17mt radials
stock tune,stock stall
times in sig
I will be goin to the track on the 19th,I honestly believe it can go 12.5 on stock stall, stock gears
Jon
2.73's, stock stall, street tires and shorty headers = mid 13's. My buddy with a 98 Formula had 2.73 gears, LT's, lid, cutout, TCI 3000 stall and M/T street radials and could only manage 12.9 @ 107. But his car did have a N20 tune so it was probably a 12.7 @ 108 car under a normal NA tune.
But he now has 3.42's and a 4000 stall. He now gets 1.7's on motor in July heat. I'm sure he'll hit 1.6's in September air.
Magnum, Here is a quote from the first post.
slp lid and bellows
Granatelli MAF
Flowmaster catback
Edelbrock shorty's (got em for free or else i wouldnt have bought them lol)
and only tuning done is we removed the torque management, no A/F tuning or transmission tuning
rubbers are BF Goodrich g-force t/a KDWS's 245/50/r16
Please DO NOT take the maximum number for everything and add it together and think you will gain this by adding these mods.
Your average full bolt-on (Intake/Exhaust) Should net you around a 50-70rwhp gain, depending on how well your car responds to the mods that you do.
You don't have LT headers, you don't have an ORY, you don't have an underdrive pulley, you don't have a ported TB, you don't have a "decent flowing" catback, you don't have an EWP and you don't have a ls6 or better intake manifold. You do have 2.73's, a stock stall and street tires which are HUGE handicaps when it comes to launching.
35 rwhp for your very limited mods is unrealistic. And the general rule of thumb for weight reduction is 100 lbs = .1 off your ET (and 10 rwhp likewise = .1 off yout ET). Removing the AC is at best a 50 lb savings making you half a tenth quicker while the CAI should net you at least 5 rwhp for another half a tenth.
Now I hate to say this but it is "possible" that the tracks equipment was off. Have you been back to the track since? If so what did you run? If not then maybe you should to see if you still have a 12.7 @ 108 car. My guess is you have a 13.0 @ 106 car with a decent launch and good air.
which is not including the EWP, or the underdrive pulley, also if you look at their number in according to the 30rwhp i stated i took the MINIMUMS not even the average......like i said i dont know what you are tryin to prove if you dont believe it WHO CARES, i drove back to schoool got and posted the damn slip for your pleasure, QUIT tryin to stick up for your buddys slow time or whatever your trying to do
my lid/muffler ta went 108-109 consistently with just those 2 mods. 78k miles on the car with stock everything else. no weight reduction, no tricks, and a nondriver haha. it's not far fetched. for you morons trying to add up his mods to match rwhp...the car only trapped 109, it's not making huge power.
and darren - you know not what you speak of. my bolt-on stalled z28 went 12.2 @ 110 @ 3600lbs...2500' DA. no tricks. just traction and simple mods. stock ls6 intake/tb, maf, pullies, trans, rear (373 gears)...but you get the idea. no ewp, or fast 90 haha. just because your **** is slow doesn't mean everyone else's **** is, too.
I bet you had LT's. Bolt ons + gears + stall makes that time very much the norm.
Really? My time is only .1 / 1 mph slower and my car doesn't have an ls6 intake, pulley or 3.73 gears like yours did. Sounds to me like my car is running pretty well considering adding those three mods should drop at least .2 off my ET. Not to mention the new stall I have hits harder then the old TCI 3500 I was running. I've all ready ran 12.3 in heat. I'm sure I can get a 12.2 out of her in September when the air cools down.
This debate is pointless. You know my position and I know yours. Lets just agree to disagree and leave it at that.
People lie on the internet all the time and for a variety of reasons. But again, maybe a previous owner put in a small 220/220 cam and he doesn't even know it. That would explain a 109 trap even with a restrictive exhaust.
His 60', ET and trap are all unbelievable for the few mods he has and street tires he was running. I'm not the only one to doubt his claims just like you're not the only one to accept them.
It appears that we will also have to agree to disagree.
maybe i should switch to a loudmouth, hooker, magnaflow, etc and trap 110+ with a lid and muffler only. i don't see it happening in central indiana @ 2500'+ da. the muffler is fine and sounds better than any of the ones you mentioned, by far.
"- Straight through setups like LM and magnaflow (pt# 14267 for just the muffler) are regarded as some of the top flowing catbacks. Flowmaster is one of the worst flowing catbacks for the LS1, it does sound good in its defense. Hooker, Magnaflow, SLP D/D are all great budget cat backs; Corsa, Borla, and GMMG round out the top of the premium spectrum."
And I agree that it does sound good. But you are giving up a little power. It still flows better then stock but just not as good as magnaflow, dynomouth, loudmouth, ect.
"- If you have an 00-02 car do not bother with shorties. They received a better-designed manifold and flow quite well actually for what they are. You will see minimal gain if any by switching to shorties. If you have a 98-99 car you'll gain some rwhp from shorties but it wont be much either."
Like I said before. Shorties will gain a little power for a 98-99 ls1 but no where near what mids or LT's will.
Here is the link to the sticky I quoted above if you were interested in verifying my information:
https://ls1tech.com/forums/generation-iii-external-engine/520845-mod-guide-induction-exhaust-please-read-before-posting.html
My 60' time was a 2.0 with Nitto DR's! Just a lil something to think about... Some cars are freaks and also nobody touched down on this, but the 2.73 A4 cars will usually trap higher than the A4 cars with 3.23 or higher geared ones...
Just My .02
And good Job with the 12.7 pass! I believe It can happen!
James
I just can't see ANY f-body, with 2.73 gears and just the most basi mods running a 12.7.
You DO NOT have the rwhp to do that with the 60' time you listed.
If the timeslip is legit then there has been more done to the car then you have stated.
More then possible that one of the previous owners slipped a small cam in there, and didn't mention it to the dealership on the trade-in or whoever he sold the car too.
There's also a real chance that the track's timing equipment is a little off.
It wouldn't be the first time that something like that has happened.
12.7?
Put the crack pipe down.
Here is something else to think about. What if you were to remove the LT's and replace them with shorties, put back the stock Y pipe with cats, replace the true duals with a flowmaster and replace the Nittos with KDWS all weather tires. Now go back to the track and find a way to run 2 tenths quicker, retain your trap speed (even though you lost at least 20 rwhp with the exhaust swap) and get .1 off your 60' (even though you went from drag radials to all weather street tires).
Sound like something that's possible to you? Sounds like mission impossible to me.
But 2.73's are better for highway races and get better gas mileage.
