ran a 12.7!!!
I don't know the exact numbers of how many left the factory with the 3.23 performance upgrade, but it seems to me that if you buy an A4 Formula, TA or Z28 you got about a 50/50 shot of having 2.73's.
The RPO codes on the door tell you for sure. GU2=2.73 and GU5=3.23.
It's really not unbelievable.
Here is something else to think about. What if you were to remove the LT's and replace them with shorties, put back the stock Y pipe with cats, replace the true duals with a flowmaster and replace the Nittos with KDWS all weather tires. Now go back to the track and find a way to run 2 tenths quicker, retain your trap speed (even though you lost at least 20 rwhp with the exhaust swap) and get .1 off your 60' (even though you went from drag radials to all weather street tires).
Sound like something that's possible to you? Sounds like mission impossible to me.
3.23 geared cars will always be quicker down the track then a 2.73 geared car with all else being equal. There is a reason why people always go numerically higher with gears when they mod. On average a 3.23 geared car will be a couple tenths quicker in the quarter mile then one with 2.73's. Add a stall and sticky tires and that gap may increase due to the severe launching handicap 2.73's impose.
But 2.73's are better for highway races and get better gas mileage.
Whether it be due to track equipment failure, or actually running a 12.7, I still say good job to the OP if he's not BS-ing us.
James
Comparing my times and mods and DA, I believe it to be possible to run 12.7 with what the OP has in 1300' DA with minor weight reduction and a slight touch of factory freakishness.
James
I've made every valid point there is to make. Some people still want to believe this (or at least not voice thier own doubts) and others clearly do not believe it. At this point it's become a personal choice.
Personally I think it's time for this thread to die. But again, that's just me.
however, i would have sold or traded the free shorties and got some lt's...
did you buy the car new? maybe the gears where changed...
Also is that 12.7 in the 1/8 or 1/4?
j/k
did this guy mention where he is from or what track he was on?
Tomtom said i did the 1/4 in 10.8 @ 127...
I call B.S.
HAHA, j/k
Jon
and some seafoam
oooh yeah i almost forgot 315 sumitomo crap in the back and diablo tuned
with of course torque management off Look at some of the other cars have run. In the "old" days of this site, I've seen 11 second stock engine set-ups. Every car will run different. Every track's prep is different. With temp difference, come DA difference. Anyone that has run in 100 degree temp knows how crappy it can be. Do the same run at 70 degrees. Big different. Run at Denver (5000+ DA all the time); same run in HRP (0' - in the winter is goes to a negative DA).
You guys need to go out and race, vice this BS bench racing. IF someone wants to try to BS their way into a 12 second run, more power to them. They are only lying to them selves. Don't lower yourself to their level.
David
