"Pushing water"
Forged pistons H beams stock crank heads new cam, springs.
Would like to run low 10’s on pump gas.
My question is I here the term “pushing water” used
a lot when power adders and LSX builds are talked about, what does this mean?
Is this new slang for a blown head gasket?
Just trying to cover all the bases before I start buying parts.
the reason why you mostly hear FI guys talking about it is because most ls series motors have 4 bolt heads and the heads will lift at big boost levels. and when heads lift water can escape between the cylinder head and the block.
i really hope you understand how much it will cost to properly turbocharge an ls series motor.
good luck
Most builders recommend studs over bolts (ARP of course), and maybe "O"-ringing the head. Some have gone as far as putting in bigger diameter studs as well as going to newer blocks like the LSX.
you will need to get a stronger cylinder head, a more resilliant head gasket, or more bolts holding the heads down
gonna try the next highest rated pressure radiator cap (using a cap off a 98 car which is probably well worn and opening less than 18 psi
) gonna try the next highest rated pressure radiator cap (using a cap off a 98 car which is probably well worn and opening less than 18 psi
