Advanced Engineering Tech For the more hardcore LS1TECH residents
11/12/13/15 "degree" heads?
Old Oct 9, 2009 | 07:27 AM
JFM-jr's Avatar
Default 11/12/13/15 "degree" heads?
What extaly is the relationship of a "degree" of a head? Is it the valve angle relative to the heads deck surface? I know the less degree the more PTV so it's going flusher to the piston in that aspect.
Old Oct 9, 2009 | 08:10 AM
Gordon0652's Avatar
I believe its the valve to deck surface angle.
Old Oct 9, 2009 | 12:21 PM
beast69camaro's Avatar
it is the relative angle between the valve stem axis and the cylinder bore axis.
it is also the relative angle between the valve face and the deck face.
both numbers are equivalent.
Old Nov 7, 2009 | 02:18 AM
DREAMZ28's Avatar
So what are the benifits of each?
Disadvantages?
Edit: I chose my words wrong, what are the effects of a higher/lower degree head. I've been hearing this term for a while and my guess on what it was was right.
It seems the lower the degree of the head, the more direct the air flow into the cylinder, but depending on the head design the air velocity might be slowed by having to go around a sharper bend. Also fluid dynamics take places with the air flow riding against the wall in the port, etc.
If anyone with knowledge on this subject is reading, please chime in. This is VERY interesting..
Old Dec 3, 2009 | 12:38 AM
AdioSS's Avatar
in the early days it allowed a smaller combustion chamber and a straighter shot at the intake valve. Now it is mainly for a port that doesn't bend as much going from the intake manifold to the valve (aka, a straighter shot at the intake valve.)
Old Dec 4, 2009 | 11:41 AM
blackz93's Avatar
Wonder why there aren't 0° heads?
Old Dec 4, 2009 | 04:10 PM
DREAMZ28's Avatar
Because the air would have to go around a tighter bend and it would slow velocity down, making it harder to reach a higher VE
