PCM ignition 1 feed wiring
I removed all my harness and organized it, when i re-installed it. the car would'nt start. I checked every single wire, and it is connected correctly. Except for the pink wire on Pin 19 on the blue connector. It is the PCM ignition 1 Feed. Now where does this go ? I have no clue. I checked the spark plugs wiring, and there is no spark. So i think it is because this wire is not connected. help!!
i gather you are talking about an LS1 PCM... if so then the blue plug pink wire position 19 goes to an igniton source in your car (pin 19 recieves 12v+ when you tunr the key onto the ignition/run position)
