Change in Flywheel weight vs HP/TQ
Loooong answer:
The engine would not produce any more/less HP/TQ at a steady rpm with a rotating inertia change (heavier/lighter flywheel). There would be a difference during engine acceleration which is happening most of the time when racing, well except maybe for the Daytona oval.
The increase/decrease in torque or hp to the flywheel or, more importantly to the wheels, depends on the total rotating inertia (wieght) and the acceleration RATE. The quicker the engine accelerates from one rpm to another the bigger the difference in hp/tq getting to the flywheel or tires.
In other words, rotating inertia makes more difference in the lower gears when accelerating than in the higher gears.
If you drop 10 lbs. from your flywheel you might notice it in 1st and 2nd gear, but if you went from 16 inch to 18 inch wheels and wider tires, the extra inertia of the tires wold probably negate the lighter flywheel's effect.
Would I spend money for a lighter flywheel if I were not racing? Nope.
Jon
Loooong answer:
Jon
Thanks for the great response. I am definitely interested in the race application. My set-up is for racing with an occasional Saturday night street spin.
In a application with slipper clutch, I believe any extra weight at the flywheel will be negative to ET. I was curious if their is a direct relationship for every 10lbs reduce related to the amount of increase TQ. You bring up a good point that the quicker the engine is accelerating the greater the benefit of reducing the rotation weigh.
Thanks again,
Bob
