self power generating electrical car?
The only way you may achieve charging of the battery is if you used the generators as brakes and only drove downhill. If a person was interested in only making one way trips then you may have a market. But then someone will have to expend the energy to bring the car back up the hill.
You cannot create more energy than you expend performing the operation to create it. If you could use low power motors to create gobs of energy via a higly efficient generator, the entire worlds energy problems would be solved.
But unless the rules of our universe change, this isnt possible.
now i'm not sure if it would actually work, it was just the thought
i have Louvers on my third gen and i though, what if in the middle sections i replaced that, or part of each row, with strips of those solar pads. i then run it to the passenger fender wheel well where its met by a battery relocation type kit.
in that well the generator or solar battery would rest.
if a person didnt want the louvers then they could apply a solar film which could almost act as a hatch tint. ( i checked they have flexible solar film)
though i do not know if its transparent
Nothing will be able to perpetuate itself, unless you can eliminate all of the parasitic loss in the system, and since that is 99.99999999% impossible in the real world it wont happen
Another thing along the same line of thinking is someone once asked me what i thought would happen if you took a fully charged battery hooked a power inverter to it, and then had a battery charger plugged into the inverter with the leads from the charger going back to the battery to charge it. would it be self sustaining? NO! because we all know that things like battery chargers and power inverters produce heat, and the production of heat prove the loss of energy from the system
Hello, i have a suggestion on producing a self power generating electrical car. i hope it will work. we need such cars due to pollution and problems associated with the pollution.
why don't you install a generator that generates electricity power in a electrical car (car with electrical motor) that this generator is spun by the electrical motor of the car and generates enough power to be stored in the car's battery while operating and using (motivating) the car this way the car will generate power by itself for itslef the electrical motor will make enough power to motivate the car and yet enough power to spin the generator to produce enough elecrical power to be stored in the car's battery to motivate the car.
when the power stored in the battery is full you cut supplying the battery with power from generator using relays or in some how,
when the battery needs power you connect the generator to bettery and supply power from the generator and so on and so fourth.
let me know what do you think.
thanks.
Abdullah
http://keelynet.com/energy/teslcar.htm
Check out the original article and commentary at the bottom of the page.
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
thanks.
Abdullah
I have been doing a lot of research the last few days on alternative fuel / free fuel / high efficiency solutions, And... Oddly enough, They HAVE invented cars that run on straight water. No gasoline or other form of fuel whatsoever. But, sadly enough, the guy who did this, All of his work magically disappointed and he died of a O/D in a parking lot. Tesla invented free electricity, If you research on this, you will discover westinghouse, shut the door on him because.... There was no way to meter it. He also invented ways of transferring energy via something like a radio wave. He had a old electronic powered vehicle, with no on board energy source at all. It was powered via electric transferred via the air. I can't explain how it works, but, if you dig around on the internet, there is a lot of documentation.
Point being... The greatest obstacle to invention and technology, is, major cooperations. Lots of great inventions and technology over the years have just "disappeared."
Sorry for the wall of text..... haha.
On the physics side, looking at it from a therotical standpoint, Water is actually a much better fuel then gasoline.
Using the e=mc2 thing.... Energy = mass * (velocity of light) ^ 2... So...
A fuel with a heavier mass, therotically has more energy.
Pure Water is 1000kg/cu.m
Gasoline is 737.22kg/cu.m
So, by following the physics here, water contains more potential energy then gasoline. But, in todays technologly, This involves breaking h20 into HHO.
This requires enough energy to break apart the bonds...... Which, usually ends up consuming more energy then its worth to make it pratical. Although, There was somebody who did a hellova job at it and made a awesome water powerd car that broke down the bond inside of the combustion chamber somehow...........
