Advanced Engineering Tech For the more hardcore LS1TECH residents
Inverted flow LS heads?
Old Sep 9, 2011 | 08:37 PM
mcm375's Avatar
Default Inverted flow LS heads?
Are there any inverted heads for the LSx platform on the market? (outboard intake, inboard exhaust)
Old Sep 10, 2011 | 02:21 AM
rsz288's Avatar
Like the new BMW twin turbo V8 engines?
Old Sep 11, 2011 | 02:48 PM
mcm375's Avatar
Exactly.
Old Sep 11, 2011 | 02:51 PM
speedtigger's Avatar
Old School Heavy
That is doable on a overhead cam engine. It would not be a simple undertaking on a pushrod motor, if at all. Lots and lots of welding and machining on the heads if it is possible at all.
Old Sep 12, 2011 | 10:04 AM
1SLwLS1's Avatar
Anyone have any links about this technology?
Edit: This is about all I could find
http://www.youtube.com/watch?v=tdbvluVB6Ok
Old Sep 21, 2011 | 05:52 PM
Krom's Avatar
makes more sense on a single turbo, where you reduce plumbing...
That's how the 4.5 duramax is/was/will be set up
An LS1 is workable with just a custom cam, (exhaust would flow out the intake valve, and ports), although the results would be much better with heads designed with the ports matched to their job (could use off the shelf cam)
Old Sep 22, 2011 | 09:35 AM
ponjohn's Avatar
When is the 4.5 Dmax set to be released....be a big hit in the Suburban.
Old Sep 22, 2011 | 08:11 PM
mcm375's Avatar
Sorry to break it to you man but the 4.5 dmax is dead.
Old Sep 26, 2011 | 04:08 AM
avatar4886's Avatar
Back in the day there were some racers that did this with Buick Nailheads. Custom ground cam was one thing required. With the nailhead it also required forced induction to make it work. Obviously special designed intake and exhaust piping/routing as well.
http://www.carcraft.com/thehistoryof...ead/index.html
What seemed to separate the nailhead-powered cars from the rest, though, was the variety, ingenuity, and downright weirdness that Hot Rodders had developed to go faster with Buicks. We found cars that were rigged with every possible multi-carb setup under the sun. Six Strombergs, two WCFB four-barrels, three deuces, and everything in between. A few of the more serious drag cars sported huge chain-drive Roots-style blowers. A wild NHRA A/D drag roadster was equipped with twin McCullough centrifugal superchargers. But one of our favorite nailhead-powered cars was a dragster photographed at the ’58 NHRA Nationals. This Buick was squeezed with a crank-driven blower, which fed pressurized air into...the exhaust ports? That would explain why the exhaust was ducted straight out of the intake. This would be possible provided the cam was re-ground to operate the valves correctly. We don't know how this reversed-port deal improved the heads’ efficiency, but it sure looks wild.
Read more: http://www.carcraft.com/thehistoryof...#ixzz1Z31npLlY
