Advanced Engineering Tech For the more hardcore LS1TECH residents
Best primary length for 6500 rpms?
Old Jul 6, 2012 | 05:51 AM
postal14's Avatar
Default Best primary length for 6500 rpms?
I am looking at building a set of headers for my project. What would be considered a good primary length to make good power around 6500 rpm? This would be for an L92 headed 6.0L with a street cam (224/228 possibly larger in the future). I am thinking of going with 1.75" diameter tubing. I will probably be walking that line between whether 1 5/8 would be better than 1 3/4 but I dont want to build more than one set of headers. Infact the whole concept of me building my own headers is a bit intimidating to me. But if thats a hoop I have to jump through then I guess Ill have to do it.
TIA: jay
Old Jul 6, 2012 | 07:08 AM
Ethan[ws6]'s Avatar
Good question! Hopefully someone has some input on this lol.
Old Jul 9, 2012 | 07:49 AM
postal14's Avatar
I was hoping someone might have a computer HP estimate program that might allow you to tweak some header numbers.
Old Jul 9, 2012 | 12:05 PM
Higgs Boson's Avatar
Seems like you really should just go with a common primary length. The torque/HP tradeoff usually comes with collector length. If you will be running an exhaust system, I'd be more concerned with where to put the X/H pipe.
Old Jul 9, 2012 | 06:55 PM
3rdGenLS's Avatar
I used my Pipemax Software and with the little info you provided, these are the Dims I got,
16 guage tubing
-- 1.75in dia tubing
-- 28in - 31in primary length
-- 3in dia collector, 17in - 18in length
Hope this helps
Old Jul 9, 2012 | 10:12 PM
postal14's Avatar
Ty 3rdgen. To be honest I have never used one of those programs and had no clue what info would be needed. I am kind of surprised that it calls for such a long collector tho.
TY for the input
Old Jul 15, 2012 | 07:55 AM
Old Geezer's Avatar
Not expensive...........
http://maxracesoftware.com/pipemax36xp2.htm
Old Aug 25, 2012 | 10:39 PM
MIKE1444's Avatar
[QUOTE=3rdGenLS;16500883]I used my Pipemax Software and with the little info you provided, these are the Dims I got,
16 guage tubing
I'm trying to see how that relates to the displacement of the engine. So, I'll just show you my thought process here.
6.0 liters>366 cubic inches
366/8 = 45.75 cu-in per cylinder.
"What cylindrical length will give me 45.75 cubic inches with 1.75" I.D. tubing"
45.75/((1.75^2)*.25*pi) = 19"
Pipemax said 28-31". The 19" is a column equal to one cylinder volume at room temperature, and that makes it a harmonic length before the collector.
I remember engineering said "avoid harmonics", so I multiplied 19" by 1.5 to get 28."
Will the program re-translate that into 1 5/8" tubing, or does it demand 1.75" tube?
