Oil Temperature
Is there a Kit?
I have found this and I can run the AN Lines...I have the two wire temp sensor..how is this wired?
http://www.lingenfelter.com/mm5/merc...E#.UXdrDrWsiSo
Thanks.
that gasket in your link which has the circular holes outlined by black is the overall shape of the removable port above the oil filter and the existing gasket, so my guess is that lingenfelter part goes there. i would drill and tap the oil pan before buying that for $99.
Here is a picture of my thermostat set up. I also put an oil pressure and temp gages in the dash of my GTO. In town driving here in Az. in stop and go traffic it get's pretty close to the 215 degrees. On the freeway it will drop down to 180 or less.
