LS1 Rear Mid-Engine AWD (C5 Corvette donor)
If you don't know how this works check youtube. The pinion bottoms out against the clutch plates, slows down and applies power to the opposite side. I'm thinking they get 33/66 front rear bias by using clutch plate material with a different frictional coeffcient on each side. If this is the case you might be able to swap the clutch plates from one side to the other to get back your rear bias. Here is the number for Torsen (585) 464-5000 if anybody wants to find out. Me I'm not building this and if I was I'd be sticking with my Audi idea. Not bad for a guy whose was called ignorant or that I have no idea what I'm talking about half a dozen time eh?
I have never seen a 4WD "mid-engine" application, I would like to ?
As for the "locker" I would fit a Wiesmann. (Traction Products)
DO NOT run a pinion REVERSE as the Trust/Coast would be opposite.
WE had NO Problem with axle rotation as our Crown could be fit to either side of the pinion.
Lance, BTW we had Mangusta owners calling to STATE they had FIVE speeds in reverse AFTER fitting a Pantera Transaxle
Rough idea what one of those Weismenn diffs would cost?
Design the body, do a simple ladder frame , that fits in the body,
Several sources can build 9" differentials and independent housings, they can assemble them in either rotation. Look at how most SUV's do the front, they use a axle housing with the diff offset and a extension tube to get the CV joints the same distance from the wheels(CRITICAL). Use True-Track diffs in both ends. New process makes the transfer case for the E46 BMW 330's as well as the transfer cases for a slug of other vehicles. Get a BMW tcase from a pre 2006 and its a straight up torque split (60/40) rear/front single speed gear drive case elegantly simple no electronic BS to deal with. You'd build a plate to make the case a divorced unit if needed.
The NP242 is another option. It is a two speed but its not hard to get rid of the low range and is cool because you can lock it, or run it as a open diff. Again dead simple no electronics to figure out. they have survived 800 ft lbs of torque in some applications.
Another option is a simple chain transfer case like the monster trucks use, they use the chains and sprockets out of a regular transfer in a simple aluminum box housing or steel.
Want brute simple? The engine layout would be mid motor rear Tranny. chain case on back of transmission, driveline gets connected between the U-loints of the differentials, Chain case bolted on pinion side of rear diff. Put a jerico 4 speed behind the engine(Short), you can ditch the tail shaft for a machined part to match the chain box to the driveline/rear end. Both diffs end up offset with a extension housing to keep that motion center consistent side to side.
For outer hub ideas look at a spec racer ford. Fairly simple setup.
Ok that was fun.. cheers.
High pinion*Pinion is above the axles) 4x4's use them..
The current ford SUV's use a nice independent diff in the rear...
Back to the top for the Jurrasic thread...
You could do that by flopping a rear end side to side so the pinion is on the opposite side of the ring gear from normal, you need some mods internally to the diff so it will lube correctly and you'll need reverse rotation gears in the diff to load correctly. This has been done a lot with the VW tranny in spec/sports racers, they flip the transaxle over so they can use it in a mid-engine layout. requires some internal work but not rocket science. Many guys have made the mistake of stuffing the ring in a vw trans from the wrong side and ended up with 4 speeds backwards..
BTW not sure if you realize this but the C5 chassis is almost useless as a base frame, because of the way they build the roll structure and pan if you change it the thing will have zero strength.. again,,, a hand built space frame chassis with a glass body is the way to go if you want a drive-able super car, ALMS prototypes would be your model. And there are several kit bodies that you might be able to use as the base skin.
I'm a virgin to the AWD scene.........but have also wondered how the GTR guys get away with running different height tires front/rear. What is the split on those cars and how does this work???
So to summarize I don't have a clue.
Overdriven gears, clutches and computers is a uneducated guess but I will find out and post as you have piqued my interest.
Sorry for the delayed response but it's been 12-14hr days at work.
To be continued......
As for front rear bias 40/60 split it has nothing to do with the size of the tire you have to run. It's how much power is being sent to the front or rear. They do this with the angle of the gear input (not all). A simple explination would be this - you have a motor winding up a rope that is pulling two different guys on toboggans up 2 different hills. One hill is steeper than the other so he would use more of the motors power to be pulled up. The other guy uses less. But they would be going at the same speed. Same thing but with gears.
There may be some internal gearing prior to the clutch pack that enables the large difference between front and rear diff ratios.
And as for flipping diffs...gearboxes upside down. It's a fairly common thing so despite it probably not being ideal, it does work.
Maybe if the setup was really pushing big numbers it might be more of a concern
1. Why add complexity when you could just have a higher front diff ratio. Which it does.
2. You wouldn't want to spin the clutch packs any fastest than you have to. Faster you spin it the more mass it has exponentially and the harder it would be to control. Its the law of inverse square.
As for flipping the gearbox like a Porsche or VW thats a transaxle and won't work for this application.
Where would you source "flipped" diffs that won't have the thrust-coast and the helical R&P backwards? Besides Weissmans? I am calling Currie tomorrow as their diffs are used in mid engine Ultra4/KOH buggies. Maybe a solution.
