Post up any car math formulas you may have.
6600 rpm clutch dump of death Administrator
CAR MATH FORMULA'S
N1) Many of the formulas use the value of pi which is 3.1415927
N2) Some formulas contain notation such as ^2 which means "squared"
Formulas for displacement, bore and stroke
pi/4 = 0.7853982
cylinder volume = pi/4 x bore^2 x stroke
stroke = displacement / (pi/4 x bore^2 x number of cylinder.
Formulas for compression ratio
(CylVolume + ChamberVolume) / ChamberVolume
chamber volume = cylinder volume / compression ratio - 1.0
displacement ratio = cylinder volume / chamber volume
amount to mill = (new disp. ratio - old disp. ratio / new disp. ratio x old disp. ratio) x stroke
Formulas for piston speed
piston speed in fpm = stroke in inches x rpm / 6
rpm = piston speed in fpm x 6 / stroke in inches
Formulas for brake horsepower
horsepower = rpm x torque / 5252
torque = 5252 x horsepower / rpm
brake specific fuel consumption = fuel pounds per hour / brake horsepower
bhp loss = elevation in feet / 1000 x 0.03 x bhp at sea level
Formulas for indicated horsepower & torque
horsepower = mep x displcement x rpm / 792,00
torque = mep x displacement / 150.8
mep = hp x 792,000 / displacement x rpm
mechanical efficiency = brake output / indocated output x 100
friction output = indicated output - brake output
taxable horsepower = bore2 x cylinders / 2.5
Formulas for air capacity & volumetric efficiency
theoretical cfm = rpm x displacement / 3456
volumetric efficiency = acutal cfm / theoretical cfm x 100
street carb cfm = rpm x displacement / 3456 x 0.85
racin carb cfm = rpm x displacement / 3456 x 1.1
Formulas for tire size & their effect
tire diameter = 2 x selection width x aspect ratio / 2540 + rim diameter
effective ratio = old tire diameter / new tire diameter x original ratio
actual mph = new tire diameter / old tire diameter x actual mph
Formulas for g force & weight transfer
drive wheel torque = flywheel torque x first gear x final drive x 0.85
wheel thrust = drive wheel torque / rolling radius
g = wheel thrust / weight
weight transfer = weight x cg height / wheelbase x g
lateral acceleration = 1.227 x raduis / time^2
lateral weight transfer = weight x cg height / wheel track x g
centrufugal force = weight x g Formulas for shift points
rpm after shift = ratio shift into / ratio shift from x rpm before shift
drivehsaft torque = flywheel torque x transmission ratio
Formula for instrument error
actual mph = 3600 / seconds per mile
speedo error percent = difference between actual and indicated speed / actual speed x 100
indicated distance = odometer reading at finish - odometer reading at start
odo error percent = difference between actual and indicated distances / actual distance x 100
Formulas for MPH RPM gears & tires
mph = rpm x tire diameter / gear ratio x 336
rpm = mph x gear ratio x 336 / tire daimeter
gear ratio = rpm x tire diameter / mph x 336
tire diameter = mph x gear ratio x 336 / rpm
Formulas for weight distribution
percent of weight on wheels = weight on wheels / overweight x 100
increased weight on wheels = [ distance of cg from wheels / wheelbase x weight ] + weight
Formulas for center of gravity
cj location behind front wheels = rear wheel weights / overall weight x wheelbase
cg location off-center to heavy side = track / 2 - [ weight on light side / overall weight ] x track
cg height = [ level wheelbase x raised wheelbase x added weight on scale / distance raised ] x overall weight
pi/4 = 0.7853982
TTT
Predicting Power
BHP = PLAN/33,000
P is brake mean effective pressure, in PSI
L is piston stroke, in feet
A is the area of one piston, in square inches
N is the number of power strokes per minute
Piston Speed
Cm = .166 x L x N
Cm is mean piston speed, in feet per minute
L is stroke, in inches
N is crankshaft speed, in RPM
Brake Mean Effective Pressure (BMEP)
2-Stroke BMEP = (HP x 6500)/(L x RPM)
4-Stroke BMEP = (HP x 13000)/(L x RPM)
L = Displacement in Liters
i.e., 80 cc = .08 Liters
1 ci. = 16.39 cc
Piston Acceleration
Gmax = ((N^2 x L)/2189) x (1 + 1/(2A))
Gmax is maximum piston acceleration, in feet per second squared
A is the ratio of connecting rod length, between centers, to stroke
Piston Stroke Motion
S = R cos X + L cos Z
S = the distance piston wrist pin is from center of crankshaft
R = the radius of the crankshaft wrist pin
L = the length of the connecting rod
X = the angle of the wrist pin
Z = the angle of the connecting rod
or
sin X = R/L sin Z
Piston Travel vs. Crank Rotation
d = ((S/2) + L) - (S/2 cos X) - L sin[cos-1 (S/2L sin X)]
S = Stroke (mm)
L = Connecting Rod Length (mm)
X = Crank Angle Before or After TDC (deg)
Note: (L) Rod Length is usually 2 times the (S) Stroke
OR
For Spreadsheets and some Calculators
HT = (r + c) - (r cos (a)) - SQRT(c^2 - (r sin (a))^2)
r = s/2
dtor = PI/180
a = d x dtor
HT = The height of piston
r = The stroke divided by 2
c = The rod length
a = The crank angle in radians
d = The crank angle in degrees
dtor = Degrees to Radians
Exhaust Systems Tuned Length
Lt = (Eo x Vs) / N
Lt is the tuned length, in inches
Eo is the exhaust-open period, in degrees
Vs is wave speed in feet per second (1700 ft/sec at sea level)
Length of Curved Pipe
L = R x .01745 x Z
L is length
R is radius of the pipe bend
Z is the angle of the bend
Diffuser Proportions
D2 = SQRT( D1^2 x 6.25 )
D2 is the diffuser outlet diameter
D1 is the diffuser inlet diameter
6.25 is the outlet/inlet ratio constant
Baffle Cones
Lr = Le/2
Lr is mean point of the reflection inside the baffle cone
Le is the length of the baffle cone
Port Open Time
T = ( 60/N ) x ( Z/360 ) or T = Z/( N x 6)
T is time, in seconds
Z is port open duration, in degrees
Compression Ratio
CR = ( V1 + V2 ) / V2
CR is compression ratio
V1 is cylinder volume at exhaust closing
V2 is combustion chamber volume
Carburetor Throttle Bore Diameter
D = K x SQRT( C x N )
D is throttle bore diameter, in millimeters
K is a constant ( approx. 0.65 to 0.9, derive from existing carburetor bore)
C is cylinder displacement, in liters
N is RPM at peak power
Crankcase Volume
Primary compression ratio =
Case Volume @ TDC / Case Volume at BDC
or
CRp = V1 + V2 / V1
CRp is the primary compression ratio
V1 is crankcase volume @ BDC
V2 is piston displacement
Resonance Effects
F = Vs / 2¼ * the square root of A / Vc (L + 1/2 the square root of ¼ A
Vs is the sonic speed Uusually about 1100 ft/sec)
A is the cross-sectional area of the inlet
L is the inlet pipe length
Vc is the flask (crankcase) volume
Average Exhaust Temperature
Determine the exhaust gas temperature in Kelvin
(k = C + 273.15). This is usually a function of the engine's BMEP.
Torque
1.00 lb-ft = 0.138 kg-m = 1.35 N-m
1.00 kg-m = 7.23 lb-ft. = 9.81 N-m
1.00 N-m = 0.102 kg-m = 0.737 lb-ft
Mass
1.00 lb = 0.454 kg = 4.45 N
1.00 kg = 2.20 lbs = 9.81 N
1.00 N = 0.102 kg = 0.220 lb
Distance
1 in = 2.54 cm = 0.0000158 mi = 0.0000254 km
1 cm = 0.394 in = 0.00000621 mi = 0.00001 km
1 ft = 30.5 cm = 0.000189 mi = .000305 km
1 mi = 63,360 in = 160,934.4 cm = 1.609 km
1 km = 0.621 mi = 100,000 cm = 3281 ft
Pressure
1.00 bar = 14.5 psi = 1.02 kg/sq-cm = 100 kPa
1.00 psi = 0.069 bar = 0.070 kg/sq-cm = 6.89 kPa
1.00 kg/sq-cm = 0.980 bar = 14.2 psi = 98.1 kPa
1.00 kPa = 0.010 bar = 0.145 psi = 0.010 kg/sq-cm
Temperature
F = 9 / 5 x C + 32
C = 5/9 (F - 32)
K = C + 273.4
Area / Volume
1.00 sq-in = 6.452 sq-cm
1.00 sq-cm= 0.155 sq-in
1.00 cu-in = 16.387 cc
1.00 cc = 0.0610 cu-in
Power
1.00 HP = 746 W
torque (lb-ft) = 5252 x hp / rpm
hp = rpm x torque (lb-ft) / 5252 The Weight of Air
14.7 lbs. per sq. inch at sea level.
Air Density Calculation
StdAirDensity = 1.22556 and is defined at 59.0F degrees, 0.0% humidity, and 29.92 inches on the barometer.
Temp_c = (Temp-32.0) * 5.0 / 9.0;
Temp_k = Temp_c + 273.0;
Baro_mb = Barometer / (29.92 / 1013.0);
Baro_pa = Baro_mb * 100.0;
SaturationPressure_mb = 6.11 * pow(10,(7.5*Temp_c)/(237.7+Temp_c));
VaporPressure_mb = Humidity * SaturationPressure_mb / 100.0;
TempVirtual_k = Temp_k / (1.0 - (VaporPressure_mb/Baro_mb)*(1.-0.622));
// D = P/(T*R)
AirDensity = Baro_pa / (TempVirtual_k*GasConstant);
% Std Density = AirDensity/StdAirDensity*100
Predicting Power
BHP = PLAN/33,000
Piston Speed
Cm = .166 x L x N
1 ci. = 16.39 cc
Piston Acceleration
or
sin X = R/L sin Z
S = Stroke (mm)
OR
r = s/2
dtor = PI/180
a = d x dtor
c = The rod length
Lt = (Eo x Vs) / N
L = R x .01745 x Z
L is length
Baffle Cones
Lr = Le/2
Port Open Time
Compression Ratio
Crankcase Volume
or
CRp = V1 + V2 / V1
Resonance Effects
Torque
Mass
Distance
Pressure
Temperature
F = 9 / 5 x C + 32
C = 5/9 (F - 32)
K = C + 273.4
Area / Volume
Power
1.00 HP = 746 W
// D = P/(T*R)
Additional Conversion Factors
1 Centimeter - 0.0328084 foot; 0.393701 inch
1 Circular Mil - 7.853982 x 10 to the negative seventh square inches; 5.067075 x 10 to the negative sixth square centimeters
1 Cubic Centimeter - 0.061024 cubic inch; 0.270512 dram (U.S. fluid); 16.230664 minims (U.S.); 0.999972 milliliter
1 Cubic Foot - 0.803564 bushel (U.S.); 7.480520 gallons (U.S. liquid); 0.028317 cubic meter; 28.31605 liters
1 Cubic Inch - 16.387064 cubic centimeters
1 Cubic Meter - 35.314667 cubic feet; 264.17205 gallons (U.S. liquid)
1 Foot - 0.3048 meter
1 Gallon (U.S. liquid) - 0.1336816 cubic foot; 0.832675 gallon (British); 231 cubic inches; 0.0037854 cubic meter; 3.785306 liters
1 Grain - 0.06479891 gram
1 Gram - 0.00220462 pound (avoirdupois); 0.035274 ounce (avoirdupois); 15.432358 grains
1 Hectare- 2.471054 acres; 1.07639 x 10 to the fifth square feet
1 Inch - 2.54 centimeters
1 Kilogram - 2.204623 pounds (avoirdupois)
1 Kilometer - 0.621371 mile (statute)
1 Liter - 0.264179 gallon (U.S. liquid);0.0353157 cubic foot; 1.056718 quarts (U.S. liquid)
1 Meter - 1.093613 yards; 3.280840 feet; 39.37008 inches
1 Mile (statute) - 1.609344 kilometers
1 Ounce (U.S. fluid) - 1.804688 cubic inches; 29.573730 cubic centimeters
1 Ounce (avoirdupois) - 28.349523 grams
1 Ounce (apothecary or troy) - 31.103486 grams
1 Pint (U.S. liquid) - 0.473163 liter; 473.17647 cubic centimeters
1 Pound (avoirdupois) - 0.453592 kilogram; 453.59237 grams
1 Pound (apothecary or troy) - 0.3732417 kilogram, 373.24172 grams
1 Quart (U.S. dry) - 1.10119 liters
1 Quart (liquid) - 0.946326 liter
1 Radian - 57.295779 degrees
1 Rod - 5.0292 meters
1 Square Centimeter - 0.155000 square inch
1 Square Foot - 0.09290304 square meter
1 Square Inch - 645.16 square millimeters
1 Square Meter - 10.763910 square feet
1 Square Yard - 0.836127 square meter
1 Ton (short) - 907.18474 kilograms
1 Yard - 0.9144 meter
POWER - AC CIRCUITS
Efficiency = 746 x Output HP / Input Watts
3ø KW = Volts x Amps x PF x 1.732 / 1000
3ø Amps = 746 x HP / 1.732 x Eff. x PF
3ø Eff. = 746 x HP / 1.732 x Volts x Amps x PF
3ø PF = Input Watts / Volts x Amps x 1.732
1ø KW = Volts x Amps x PF / 1000
1ø Amps = 746 x HP / Volts x Eff. x PF
1ø Eff. = 746 x HP / Volts x Amps x PF
1ø PF = Input Watts / Volts x Amps
HP (3ø) = Volts x Amps x 1.732 x Eff. x PF / 746
HP (1ø) = Volts x Amps x Eff. x PF / 746
1 KW = 1000 Watts
Eff. = Efficiency, PF = Power Factor, KW = Kilowatts, HP = Horsepower
POWER - DC CIRCUITS
Torque = HP x 5280 / RPM
HP = Torque X RPM / 5280
1 HP = 36 lb.in. @ 1750 RPM
1 HP = 3 lb. ft. @ 1750 RPM
Eff. = Efficiency, HP = Horsepower
OHMS LAW
Volts (E) = Amps (I) x Ohms (R)
Amps (I) = Volts (E) / Ohms (R)
Ohms (R) = Volts (E) / Amps (I)
R=Ohms, E=Volts, I=Amperes
To figure miles per hour, multiply the engine RPM by the Wheel Diameter in inches and divide this by the Gear Ratio times 336
or
MPH = RPM * wheel diameter (in inches) / gear ratio * 336
To figure engine speed (RPM), multiply by the Speed in MPH, by the rear axle gear ratio times 336. Divide this by the tire diameter in inches.
or
RPM = MPH * gear ratio * 336 / tire diameter
POWER - AC CIRCUITS
1 KW = 1000 Watts
POWER - DC CIRCUITS
OHMS LAW
or
or
Weight of Fuel
The Specific gravity of 92-octane gasoline is 0.75
Leaded race and unleaded 87-octane street gasolines can test below 0.75.
(Specific gravity is the weight of a material relative to that of water.)
1 Gallon of Water Weighs 8.03 lbs
1 Gallon of Gasoline Weighs 6.02 lbs
Air Consumption
A gasoline racing engine consumes about 1.3 to 1.4 cfm of air per HP.
An alcohol racing engine consumes about 1.2 to 1.3 cfm of air per HP.
BSFC
Brake Specific Fuel Consumption is a formula to determine the efficiency of an engine.
The formual is:
Fuel (in pounds) consumed per hour / Engine Horsepower
A 1,000 hp engine with a BFSC of 0.5 would consume 500 lbs of fuel per hour (83 gallons).
Racing engines BSFC values usually range from 0.4 to 0.48
Carburetor Flow Rating
Four-barrel carburetors are rated at 1.5 inches HG (mercury) (20.3 inches water)
Two barrel carburetors are rated at 3.0 inches HG (mercury) (40.6 inches water)
EGT
Exhaust Gas Temperature of a gasoline racing engine should be 1350º F - 1400º F.
Horsepower and torque
BHP = T x RPM ./. RPM
or
T = 5252 x BHP ./. RPM
BHP = Brake horsepower
T = Torque (ft/lbs)
RPM = Engine speed in revolutions per minute
Valve Spring Rate
R = (OL - CL) ./. (IH - OH)
R = valve spring rate
OL = open load
CL = closed load
IH = installed height (closed height)
OH = Open height
Air Consumption
BSFC
The formual is:
EGT
or
T = Torque (ft/lbs)
Valve Spring Rate
OL = open load
CL = closed load
OH = Open height
all you need is this website
http://www.smokemup.com/auto_math/index.php
Just enter your data and it will do all the calculations for you
J-Rod... I haven't heard of taxable HP....
Please explain.
Nice work J -rod!!How bout this :Lots of dollars +well chosen parts +hard work=more hp and or faster car!
Don"t pick the cam with the biggest #"s![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Don"t campare your(similar) combo of parts to someone else"s and expect the same hp!
Asking to pick a cam-doing a search=stupid responses+harsh remarks!!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
Originally Posted by avezz28
Can you expain in detail how to calculate the center of gravity?
For a complete vehicle it's probably easier to measure than to calculate.
Basically you "scale" the car or check the weight on each wheel with the car sitting level. You then raise either the front or rear some distance (2 ft or so), and recheck the weights on the two wheels. A few moment calculations and you have CG.
It's a little more complex in reality. You can't let suspension move, fluids like fuel mess up the calculations, and the second measurement is sometimes difficult to get correct.
Oh, you can find left-right location also with these calcs.
For non round parts, it's probably still easier to measure than calculate. Hanging the part or assembly from cables (or wires for small parts) at different orientations and projecting the wire line thru the part will give pretty good results.
For a complete engine or engine/trans combo, using the vehicle scaling method would work
Any particular thing you want to find CG of?
Fuel related equations:
One of the most common questions relating to engine fueling is:
How much hp can my injectors support?
Max fwhp = (Injector Flow Rate)(# of cylinders)(Injector Duty Cycle)/(bsfc)
Finding the flow rate of an injector rated at a different pressure:
Injector Flow Rate(new) = [sqrt(new fuel pressure)/sqrt(old fuel pressure)]*Injector Flow Rate(old)
Common values for BSFC:
NA: 0.4 - 0.5
Nitrous: 0.5 - 0.6
FI: 0.6 - 0.7
NA: 0.4 - 0.5
Nitrous: 0.5 - 0.6
FI: 0.6 - 0.7
