408 lq4 bearing clearances
Specifics
Early lq4 block
Bored .030 line honed deburred etc at SAM
Box stock Lunati Voodoo forged crank
Box stock scat I beams
Wiseco -8 cc dish pistons with reliefs for l92/ls3 valves k394x3 with wiseco pins and rings
Clevite h main bearings
King x Rod bearings
Durabond cam bearings
Here's what I need
Cam clearance
Main clearance
Rod clearance
Crank and camshaft endplay
Ring gap 90% street/10% street raced...small shot 200 or less.
Rod side clearance
If anyone has a similar setup or a good weath of experience and knowledge I'd appreciate the response. Only want to build this once I'm on a super tight budget and can't afford to build it twice.
Thanks in advance.
My main and rod bearing clearances are both .0027".
My pressure at idle hot is about 47 psi
My pressure at 4500 rpm hot is about 80 psi
It will generally make 95-100 psi anything over 6000 rpm if stationary on a dyno
Durning a run the pressure will spike around 95-100 psi as soon as I let go of the transbrake, but will fluctuate between 95 and 75 psi throughout the run. Likely due to acceleration forces and the general design limits of the ls pump.
